corvette air conditioning-yours cold?
Old Feb 21, 2008 | 10:06 PM
2003 electronblue's Avatar
2003 electronblue
Default corvette air conditioning-yours cold?
hi everyone, i just put my air on today, 80 here in fl, and i don't like the way it cools, i think it should cool alot better, my question is , is the corvette c5 known for poor airconditioning? is everyone happy with there air? i have the convertible but did buy the trunk divider. p.s. it blows cool not cold. any oppinions?
Old Feb 21, 2008 | 10:13 PM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
Mine will freeze anybody's A$$ off! Your's should to! Something is not right if it doesn't
Old Feb 21, 2008 | 10:14 PM
PEW01's Avatar
PEW01
Old Feb 21, 2008 | 10:18 PM
CJR2's Avatar
CJR2
St. Jude Donor '08
My 03's AC was ice cold last summer. I never was hot even though we had 95 degree and 99 percent humidity. You may have a freon leak.
Old Feb 21, 2008 | 10:23 PM
Johnny Hardcore's Avatar
Johnny Hardcore
Yeah, mine sucks. Same deal. Blows cool, but not cold. Probably a freon leak or blown compressor. I just haven't justified the cost of an AC fix over a performance mod.
Old Feb 21, 2008 | 10:24 PM
apriliacati's Avatar
apriliacati
If its not cold enough, it probably needs a charge.
Old Feb 21, 2008 | 10:32 PM
Plasticfan's Avatar
Plasticfan
I think C5 AC's are great. Mine will freeze the b**ls off a brass monkey. Stick a thermometer in the center air duct. You should see mid 50's going down the road at 80 ambient. As was mentioned earlier, you may need a light shot of refrigerant.
Here's a chart for some detail.
Old Feb 21, 2008 | 10:37 PM
jrose7004's Avatar
jrose7004
You could hang meat in mine.
Old Feb 21, 2008 | 10:44 PM
Kotlas's Avatar
Kotlas
Agreed, something is wrong.
I am in Orlando, and if I leave it on low by accident I start to freeze.
Old Feb 21, 2008 | 11:46 PM
damilleniumboy's Avatar
damilleniumboy
I do that part anytime I drive mine, and yes the A/C is freaken cold.
Old Feb 21, 2008 | 11:58 PM
Jet-Jock's Avatar
Jet-Jock
Same here coldest I ever set it is 69°F. Auto when I first get going it will switch to internal recirc then switch to normal mode once the temp is reached. But I usually run it between 70-72°F and that makes it pretty cold inside. (vert too - no mods)
Old Feb 22, 2008 | 12:05 AM
gpracer1's Avatar
gpracer1
I store ice cream in mine even when its 110 out.
20% tint helps too.
Old Feb 22, 2008 | 12:09 AM
Cozmo's Avatar
Cozmo
CentralTX Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
Default Read this, it could save you a lot of money!!!!!!!
It should cool very well. Their have been some instances that I have read about in which the battery leaked acid. Seems that some of the AC hoses are located under the battery.
You should pull you battery and tray beneath it and check for hose issues.
Old Feb 22, 2008 | 12:12 AM
Jet-Jock's Avatar
Jet-Jock
Might also have the freon R134A level checked and a leak check if it is low.
Old Feb 22, 2008 | 12:19 AM
fireman591's Avatar
fireman591
Check the Freon level.
Sounds like it is low.
Old Feb 22, 2008 | 03:29 AM
Jistari's Avatar
Jistari
I like that . . .I'll use that
Old Feb 22, 2008 | 07:59 AM
s'noJob's Avatar
s'noJob
Couldn't tell ya. Haven't owned it long enough to try it.
s'noJob
To corvette air conditioning-yours cold?
Old Feb 22, 2008 | 08:26 AM
2 GRUMPY's Avatar
2 GRUMPY
Mine gets so COLD it makes the Old Ladys High Beams stay on !!!!
Old Feb 22, 2008 | 08:30 AM
s'noJob's Avatar
s'noJob
Originally Posted by LIGHTMAN
Mine gets so COLD it makes the Old Ladies High Beams stay on !!!!
Yeah, that would be pretty nippy.
s'noJob
Old Feb 22, 2008 | 08:42 AM
bassvet's Avatar
bassvet
St. Jude Donor '10
Check to see if your throwing any codes. May have to have the air door recalibrated. Had that problem with the 04.
