[Z06] Window leaking air?
Old Feb 23, 2008 | 04:27 PM
meldog21's Avatar
meldog21
Default Window leaking air?
The other day I had the chance to run it up a little and my drivers window started leaking air in at above 150. The car is an 02 Z06. Is this normal? Or do I need to adjust the window?
Should I take it to the dealer?
Dog
Old Feb 24, 2008 | 11:22 AM
2K3Z06's Avatar
2K3Z06
From: KADS- If it has wings or an engine, I can break it. Dallas TX
that's kinda normal at that speed. I tried adjusting the window, didn't seem to help much.
It seems to depend on the wind, a strong crosswind at that speed seems to make it worse, I know my hood really shakes when i go that fast in a strong crosswind.
I had my car up to 130 this morning, no hood shake, no window leakage.
you could also check the window stops around the a-piller, might be little out of adjustment.
best of luck, rob
Old Feb 24, 2008 | 07:02 PM
TEXHAWK0's Avatar
TEXHAWK0
You should have the windows down on the race track, and I am sure you are not driving 150 MPH on the street...
Old Feb 24, 2008 | 08:31 PM
tlc0706's Avatar
tlc0706
Old Feb 27, 2008 | 11:03 PM
DA KAR's Avatar
DA KAR
Active Streak: 90 Days
In cold weather climates the air is thinner....so you"ll hear more leakage in the winter...not sure whay your climate is though.
Old Feb 27, 2008 | 11:55 PM
ZEEEEOOOOSIC's Avatar
ZEEEEOOOOSIC
Roll it up!
To Window leaking air?
