[Z06] 2001 Z06
Old Feb 24, 2008 | 03:33 PM
61 Silver's Avatar
61 Silver
Default 2001 Z06
Hi!
I am a C-1 owner that might be in the market for a newer Corvette.
I just looked at a 2001 ZO6 with about 26,000 miles. The car is very clean in side and out, but there seemed to be an engine knock or noise. The owner who is the second owner stated that the noise has always been there.
The car is very original with all it's original parts except for tires with 4.000 miles on them.
What should one look for when buying a 2001 Z06. Has anyone experienced problems and if you have, at what mileage did the problems start.
Thanks for any help!
Ray
Old Feb 24, 2008 | 05:38 PM
PeteZ06's Avatar
PeteZ06
St. Jude Donor '07-'08-'09-'10-'11
Seems like theres a weekly posting about '01 Z06's.
Please do a search, youll find more info than you need since everything has already been covered 100 times
Good luck with your purchase.
Old Feb 24, 2008 | 07:56 PM
NVR KNO's Avatar
NVR KNO
Just recently bought a 01 Z with 17k miles on it. I dont have any engine noise like that. All vette motors are gonna sound like a sewing machine.... valvetrain. But no knocking.
When looking for a Z, 01 or any year, just make sure its meachanically sound. There is no body damage, clutch is good, brakes, tires. 01 Z is just as good as any other year.... Theyre all Z06s!!!
Old Feb 24, 2008 | 10:14 PM
1962 Fuelie's Avatar
1962 Fuelie
Default It's amazing where you turn up.....
Hello Ray, greetings from the other guy with the fawn beige fuelie....
I have an '01 Z w/ 48,000 mi, an '01 w/ 6,000 mi and an '03 w 6,000 mi.
I have never heard any engine knocking sounds. There is a knocking sound that IS NORMAL when the clutch is disengaged on 01's - 04's. It is like a throw out bearing clatter or rattle but is a rather deep sounding rattle. Depressing the clutch stops the noise.
While some of the early 01's had some oil consumption issues, other than a small oil leak out of a differential seal, I have had absolutely no trouble. The Z's are unbelieveable cars with torque, power, handling, stabilty and decent fuel economy. Yes I said it... Decent Fuel economy. Cruising at 85mph in 6th and a downshift to 4th with a little pedal, very quickly yields a rock steady 140 with lots more to go. If you get one that has been well cared for, you will get an unbelievable performance value for the money my friend... Good luck, hope to see you in Carlisle.... Best Regards.... Butch
Old Feb 24, 2008 | 11:14 PM
z06inVB's Avatar
z06inVB
My 01 was built in November 00 has never had any work done on the engine is totally stock and just rolled over 80k miles. Other than routine maint. it has had a fuel sending unit replaced, toe rod ends, brakes once, I installed a CAGS bypass which failed and I repaired and the CLB. Right now it shoots a P1416 code which is no biggie and shifting from 3 to 4 can be a little rough when cold..synchro I am sure..oh and it leaks water in weird places. No oil burn issue ever. I look forward to rolling over 100k with her..now if I could find those water leaks....
Old Feb 25, 2008 | 05:32 AM
dieseldave56's Avatar
dieseldave56
Default Piston slap.............
You don't say if the noise goes away after warm up. Early '01 LS6(pre April '01) had cold start piston slap . Actually the cold piston slap had limited complaints steming back as far as '97.
The piston slap anomoly has been occurring in some engines on cold startup and GM says it is NOT a durability concern . Like the oil ring change there is no performace gains in switching to the tighter pistons. Those hearing the cold piston knock are better off just ignoring the sound till the engine warms up, according to GM engineers.
Gm reduced the piston to bore tolerance and added new pistons with an anti friction polymer . No real performance gain , but done to address customers concerns.
My '01 Z06 ( production date June 18th '01) is a great car without either piston knock or oil issue. Did have the axle seal changed at 900 miles and the steering colum lock fix. No other issues. My car also has 27,000 miles to date. Good luck
Old Feb 25, 2008 | 11:32 AM
BANDIT HPT's Avatar
BANDIT HPT
You'll have a hard time finding a LS1/LS6 that doesn't have piston slap when it's cold.
To 2001 Z06
