Removing stock Ti system ?
Old Feb 25, 2008 | 11:02 AM
Z06Frank's Avatar
Z06Frank
Default Removing stock Ti system ?
Hi,
I got a quick question is it possible to remove the stock Ti system with just putting the car on a set of ramps ? I dont want to cut it also.
Thanks !
Francois G
Old Feb 25, 2008 | 11:13 AM
WKMCD's Avatar
WKMCD
Originally Posted by FrankyG
Hi,
Thanks !
Francois G
Not on ramps. You need to raise it really high - maybe 36 inches.
Old Feb 25, 2008 | 11:27 AM
SebringSixSpeed's Avatar
SebringSixSpeed
To change mine I had to use a floor jack with a couple of 2x6s to get the rear high enough to get out my stock exhaust. Like the other guy said about 36 inches. Its up to the point that the front bumper cover just kisses the ground.
Old Feb 25, 2008 | 12:25 PM
Bill Dearborn's Avatar
Bill Dearborn
Don't cut it. The exhaust on a C5 can be removed without cutting. The Ti is worth a lot more money on the used market if isn't cut.
Bill
Old Feb 25, 2008 | 12:47 PM
Z06Frank's Avatar
Z06Frank
ok I guess that answers my question i dont have access to a lift how would you recommend I lift the rear of the car 36 iches off the ground ??
Old Feb 25, 2008 | 01:06 PM
Tom/99's Avatar
Tom/99
You need to get it up at least 30 inches. That from the botton of the rear bumper to the ground. The hardest part of the job, is jacking it up high enough. I changed out the stock exhaust for a Ti system in just under an hour, from start to finish.
Old Feb 25, 2008 | 01:15 PM
renegad44's Avatar
renegad44
From: This is not a Song, It's an Outburst: Or, The Establishment Blues; Sixto Diaz Rodriguez
Cutting is like throwing money away. Find a way of unbolting them.
Old Feb 25, 2008 | 01:22 PM
FASST LN's Avatar
FASST LN
If you are out of options, you could always look for a retaining wall and back your car up to the edge.
Just don't back up too far!!
pit-man's Avatar
pit-man
Here's what I did to make it easy.
http://i160.photobucket.com/albums/t.../TIRemoval.jpg
Pit
Old Feb 25, 2008 | 01:49 PM
Bill Dearborn
Pit
I did pretty much the same thing although I didn't use the ramps on the trailer I just jacked the car up. Now I have a scissors lift and don't have to worry about those problems.
Bill
Old Feb 25, 2008 | 01:50 PM
bumble-z's Avatar
bumble-z
Pit
Hey, I like that!
Old Feb 25, 2008 | 04:51 PM
ciphfer's Avatar
ciphfer
Navigator
what year is the car?
I may take them off your hands if it is good shape and fit my 99 vert.
Old Feb 25, 2008 | 11:43 PM
Whiteonrice's Avatar
Whiteonrice
Why not spend the $50 bucks or so and go to a muffler shop. You'll get a lot more than that out of the uncut TIs and just maybe you can have your new exhaust installed for a little more. My life is worth more than $50-100 bucks.
Rick
Old Feb 26, 2008 | 07:04 AM
Take it to a muffler shop and have them do the work. That's what I did and they charged me $50 for the job - took about an hour.
Old Feb 26, 2008 | 08:24 AM
Z06Frank's Avatar
Z06Frank
I prefer to do it in my driveway ! and the exhaust is coming off a 2002 Z06 with 22K miles on it.
Old Feb 26, 2008 | 09:04 AM
Vega$Vette's Avatar
Vega$Vette
Rick
Jack stands and wood and ramps up over 32" is a really bad idea.....Unless you have a Death Wish
Old Feb 26, 2008 | 12:54 PM
chuck1026's Avatar
chuck1026
Cruise-In II Veteran
Still alive ...
I saw a picture of a guy who backed his C5 to the edge of a loading dock to change it out... great idea if you have access to one.
Chuck
Old Feb 26, 2008 | 02:06 PM
Tom/99's Avatar
Tom/99
Jack stands, I don't own any, I just used 2X4's on my floor jack, like the picture to do mine.
To Removing stock Ti system ?
