A question about changing tires
Old Feb 25, 2008 | 11:18 AM
Rick Church
Guest
Posts: n/a
Default A question about changing tires
I'm looking at buying a C5 vert with EMTs (run flats). I'm used to a ZO6 without them. I know the regular C5 EMTs (tires and wheels) have tire pressure sensors. What needs to be done when changing from run flats to regular tires (besides buying a ZO6 tire repair kit)? Does the DIC / computer get bad information when the sensors are removed? Can the sensors simply be removed? Does anything in particular need to be done to the computer once the wheel sensors are removed? Sorry about all the dumb questions!
EDIT: I forgot to mention that I am changing rims and going to all C6 ZO6 chrome wheels. Does that change the information in all the replies? I don't know where or how the wheel sensors attach.
Thanks in advance!
Old Feb 25, 2008 | 11:20 AM
SebringSixSpeed's Avatar
SebringSixSpeed
Why can't you just reinstall the sensors with the non-runflats. I did and they work just fine.
Old Feb 25, 2008 | 11:38 AM
JohnnyB's Avatar
JohnnyB
I went with non-runflats last summer. According to my research, my computer would not be able to be flashed to stop showing a message about the TPMS (my car is a 2000). That being said, I believe the warning only comes up when starting the car and can be reset each time using the buttons on the DIC.
After I thought about it, I ordered new sensors (so the batteries would be fresh) and had them placed in my non-runflats. That way, my first indication of a leak will come early and maybe give me enough time to get somewhere or at least off the road without too much damage. I didn't want my first indication of trouble to be when the tire was actually flat and I started feeling it in the car.
Old Feb 25, 2008 | 12:04 PM
mike348's Avatar
mike348
I went to non run flats and feel good that the sensors will let me know when a tire goes below 25 lbs.
Old Feb 25, 2008 | 12:13 PM
Toms2001PewterC5's Avatar
Toms2001PewterC5
Use your sensors with the new non run flat tires. Not a problem.
Old Feb 25, 2008 | 12:17 PM
rws.1's Avatar
rws.1
The sensors are perhaps even more critical with regular tires.
In pre 2001 you cannot turn the sensors off.
In 2001 and newer you can turn off the sensors.
Old Feb 25, 2008 | 01:50 PM
R Devil's Avatar
R Devil
Old Feb 25, 2008 | 02:03 PM
Rick Church
Guest
Posts: n/a
ttt due to editing the thread.
Thanks!
Old Feb 25, 2008 | 05:23 PM
Lancer033's Avatar
Lancer033
and on the 01 and newer cars, you can just hit the reset button on the DIC and go own down the road until you get around to getting the programed off.
Old Feb 25, 2008 | 07:57 PM
JimZRyd's Avatar
JimZRyd
St. Jude Donor '12
I did the same it works just fine
Old Feb 25, 2008 | 08:01 PM
Vega$Vette's Avatar
Vega$Vette
That's the what I did with my CCWs a P-zeros.
Old Feb 25, 2008 | 08:02 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
You can mount a sensor in any wheel, and they can be used with any tire.
If you like the ability to read your tire pressures, and don't like resetting dash warnings every time you start the car, then simply put the sensors in the new wheels.
Old Feb 25, 2008 | 09:01 PM
C5 4 ME's Avatar
C5 4 ME
Old Feb 25, 2008 | 10:56 PM
Rick Church
Guest
Posts: n/a
I have never seen a tire sensor. How do they mount to a rim?
Thanks,
Rick
Old Feb 25, 2008 | 11:23 PM
Whiteonrice's Avatar
Whiteonrice
Air pressure is air pressure. The sensor doesn't know what kind of wheel it's on.
Rick
Old Feb 26, 2008 | 05:15 AM
unionlandlord's Avatar
unionlandlord
C5 General
From: Boosted in Manhattan & Round Rock TX. President of the Non Club Club of Kansas and Round Rock , Not the flat part.
Thanks,
Rick
Old Feb 26, 2008 | 08:49 AM
RSchleder's Avatar
RSchleder
Keep the TPS and you'll have an extra level of safety and information if a tire is going down in pressure!
To A question about changing tires
Old Feb 29, 2008 | 02:25 AM
crignaj's Avatar
crignaj
So can a early c5 (1998) sensor be used in the newer c6 wheels? I'm looking at getting a set of c6 takeoff's & hope to just swap sensors.
Old Feb 29, 2008 | 02:48 AM
unionlandlord
C5 General
Yes you can, you may need a little rubber O ring. No biggie.
Paul G.
Old Feb 29, 2008 | 04:02 AM
gpracer1's Avatar
gpracer1
I scroll through the TPS every time I drive just to see if my tires are at temp so I know they will hold when I
