So I left work on my lunch break only to find my 1999 won't start I'm trying to troubleshoot this thing in the remaining hours I have left at work, but I'm fully prepared to not drive it home! The symptoms are as follows:
Brand new full tank of gas after previously being very low. (Possibly bad gas??!?!) Car ran fine for about 30 minutes. Car was parked for about 10 minutes and started back up fine.... 6 hours later... car starts briefly then stalls. Won't start back up. Engine turns over fine, but won't start.
I'm thinking it's either a fuel issue or ignition issue, but am unsure how to proceed troubleshooting. Any help would be GREATLY appreciated. As of now, I'm STUCK AT WORK!
P.S. Gas was HESS Premium. I just read in another thread someone else having trouble with HESS due to ethanol content... not really sure about this though?
Do you hear the fuel pump making a noise when you turn the ignition on? You may have an oil pressure sending unit that's disconnected or bad.
Do you have the spare key by chance? Possible cause by a dirty resistor?
Unfortunately, no. I'm not the original owner and didn't ever bother to get a spare made. I'm reluctant to thing it's a "security" issue though since the car does crank. If it were a security issue, would the car still crank?
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
The car will crank if it's a VATS issue - it won't turn over. Check to see if there is a piece of lint or any foreign matter on the pellet.
Did you run the codes? You only need to have the ignition on to do it.
I think I'm a little confused on cranking vs turning over, I've always used them interchangeably. I guess technically cranking refers to the starter, while turning over refers to the motor? Either way, the motor is turning. As I said in my first post, the car did start for a BRIEF period before stalling. This too leads me to believe it's not VATS.
I've been reading about the Schrader valve on the driver side fuel rail. I turned the key to the ON position and pushed the valve. Nothing at all came out. Is this indicative of a fuel pump failure?
It could be the fuel filter....running the fuel way down, means you start to pick up all of the junk that collects in the bottom of the tank. Usually though it will start after the car starts and the gunk has a chance to settle.....hmmmm.
Also have a listen and make sure your fuel pump is running. It's right in front of the drivers side rear tire. Have someone turn your ignition on (not crank) while you listen for the pump.
with the key in the on position, the fuel pump should pressurize the system. even with the car off for several hours i get fuel spraying out of the schrader valve when i depress it.
i would try cleaning the pellet first but it sounds like a fuel pressure problem.
Just read through the thread. Makes me feel a little better knowing I'm not the only one having issues today. However, the issues in the referenced thread seem a little different than mine. Mine started only ONCE for about 2 seconds. After that, no ignition at all. I'm going to look into the fuel filter as a possibility. I really don't want to change out a fuel pump in my work parking lot
Speaking of fuel pumps. I did try to listen if the pump was running. I put my ear to the car to listen for it, but didn't have any help. Should I be able to hear it run with the ignition in the ON position, or will someone have to try and start it? I know torchredfrc just said:
But I just want to be sure I'm not listening in vain. For the record, I didn't hear anything. At this point, should I be leaning towards fuel pump? The car is a 1999, but only has 70,000mi on it. Would it be out of the ordinary to see fuel pump issues with this kind of mileage?
I also read in the referenced thread that a disconnected ground could be causing the fuel pump not to work. Any merit to this?
Thanks again for helping me out guys! I really really appreciate everyone's input. I'd be lost without it!
My car is a 99 with around 85,000 miles on it. I would honestly say you're more likely to have problems with the fuel filter being clogged than the fuel pump dieing on you. However, if you're not hearing the pump turn on maybe it is the culpret. Have you checked your fuzes?
Not yet. I had to leave the car at work overnight. Not too thrilled about that.... But I will check them first thing in the morning. Which fuses should I be checking?
Also, regarding the filter. I've been reading that our filters are still outside the tank, but where exactly is the filter located? Is it pretty easy to replace? If so, I'll just replace it and see what happens.... go from there.
Hope you figured it out. Sure sounds like you have no fuel pressure if you tried the schrader valve. So it has to be A. the fuse B. the filter or C. the pump. If it's the fuse you have to wonder why it would go. Anyway good luck, tell us what you find.
Check Relay #35 and mini fuse #13 in the under hood fuse block. I'm making some PDF's for troubleshooting for you. I'll have them posted shortly.
This is going to sound like a stupid question but are you sure you have fuel? The level sensor in my 99 is flaky at times and I find I often have less fuel than the gauge indicates.
Where are you located? If you happen to know someone with a Tech-2 you can do some pretty detailed diagnostics. It's always good to fill out your profile so if someone here is in your area you might even find a helpful hand to turn a wrench in a parking lot.
Thanks for working on those PDF's! I really appreciate it. I'll check the relay/fuse in the morning. Hopefully that'll be it although it probably won't be that easy! Regarding fuel, I actually JUST filled the tank on my way into work. The tank was pretty low when I filled it, so I suppose it is possible I sucked up some crap and clogged the filter. I'm curious though, how frequently do these things (clogged filter / failing pump) result in sudden lose of fuel supply. Wouldn't a failing pump cause problems prior to just all out quitting on me? At any rate, thanks again for working on those PDF's. I'll make sure to put em to good use in the morning! Oh btw, I'm in Southern NJ, outside Philadelphia.
