Silicone brake fluid
Old Mar 1, 2008 | 10:40 AM
pec98's Avatar
pec98
Default Silicone brake fluid
Has anyone switched to silicone brake fluid? I,m aware you must completely rid the system of the DOT #3 fluid first, but is a regular bleeding enough,or is there more to it?
Old Mar 1, 2008 | 10:45 AM
02MillenniumVette's Avatar
02MillenniumVette
Ive heard that it will mess up your ABS system if you use the silicone fluid. Im not sure how true that is though.
Old Mar 1, 2008 | 10:49 AM
ErnieN85's Avatar
ErnieN85
Very true Dot 5 will foam (air bubbles) and make a soft pedal with ABS systems
DOT 3,4 & 5.1 are all useable in a street car
Old Mar 1, 2008 | 11:06 AM
DefenderC5's Avatar
DefenderC5
What he said, DOT 3,4 & 5.1 only. Do NOT use Dot 5.
I used some Valvoline Hi performance Dot 4... I can't really tell the difference honestly.
Old Mar 2, 2008 | 12:01 AM
MNCrystalRed2011's Avatar
MNCrystalRed2011
To Silicone brake fluid
