From: Boosted in Manhattan & Round Rock TX. President of the Non Club Club of Kansas and Round Rock , Not the flat part.
Ac Help......
97 38k miles MN6 Dule AC
It was a nice day in Kansas so I put the AC on. No cold AC came out. The AC light flashed and then goes off. I tried it 5-6 times same thing. Ran the codes and 0 HVAC codes. No C codes at all.
I added some long tube headers a wile back and thay were close the the AC line. I put somw heat wrap on it. I did not try the AC aftor the headder install till now.
Make sure your outside temp reading on the display is correct. My sensor went bad last week, displayed 34 even though it was 65 outside. This will keep your A/C from coming on if the readout is 38 or below. No Corvette Tax here as it is used on most late model GMs, sensor was $11 at my local dealer, part# 10248414. About 5 minutes to change it. Hope this helps!
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
The A/C should come on with an ambient temp of 72 degrees. Maybe you have a low charge in the system. Someone with gauges should be able to read the low and high side pressures to see if you have enough refrigerant.
Originally Posted by RrCoX22
you may have a leak or it may have lost its pressure (vacum)... checking the gauges and adding some freon hopefully should fix it
Im going to put some gages on it and see what happens. Thanks guys.
