Revving engine while car is in storage
Old Mar 2, 2008 | 12:50 PM
StevieB's Avatar
StevieB
Originally Posted by bmacZO6
Please guide me to the location of this information.
I can’t remember where. If you want to follow GMs detailed information for storage is ridiculous. I can’t remember where to find that either. A couple of their recommendations are to put the car on stands and wrap the tires in big plastic bags. That may be for very long storage times though.
I figured this Smiley out
Old Mar 2, 2008 | 12:58 PM
StevieB's Avatar
StevieB
Originally Posted by itzza427
I'd say it's better to keep that kind of RPMs under load.Cylinder pressure under load keeps the piston geometry more stable especially the ring seating .That kind of free revving is not good for rings ,rods and rod bearings.
This was the kind of thing that made me really think of what i'm doing. I'm going to run it, to keep this scuffing microcopic stuff at a minimum at the expense of causing serious damage? That would be really stupid
HUH, Your explaination is a huge concern. (pondering smiley)
Old Mar 2, 2008 | 01:07 PM
StevieB's Avatar
StevieB
Originally Posted by Bvette2000
My car is stored during the winter months as well (in a heated garage). It's not a
system, the exhaust is not going to rust out and most of us are burning premium fuel.
Yea, I'm not concerned about exhaust issues. I'm talking about the possibility of carbon build up on the valves. At least that was what I was told when I was 17 years old, seriously.
Old Mar 2, 2008 | 01:11 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
http://www.corvetteactioncenter.com/...e/storage.html
On page four at the top of the page in the article referenced above it says:
Engine Start
Last but not least: "Should I start my Corvette periodically, or leave it alone until it's ready to come out of storage?" This is definitely the most commonly asked question when it comes to automotive storage and there seems to be two opposing sides. One side feels that you should start your car at least once per month and let it run for a good 20 minutes plus until the cooling fans kick in. The other side feels that you should leave the car alone until it's time to remove it from storage. Again, we asked David Scott at GM. "It is always best to start your vehicle once a month if possible."
But the article doesn't say anything about revving the engine to redline....and personally I cannot imagine that there would be any benefit to this practice. This is one opinion......
Old Mar 2, 2008 | 01:20 PM
xlr8nflorida's Avatar
xlr8nflorida
I would run the car, let it idle and run all the accessories etc.
I would keep the car idling with taps of the gas up to 3,000 RPMS.
I would never rev it to redline while the motor is no under load.
Old Mar 2, 2008 | 02:14 PM
bmacZO6's Avatar
bmacZO6
Engine Start
This article appears to quote David Scott at GM about starting the car while in storage. It does not say whether this is his personal opinion or not. I have yet to read that any manufacturer, as a matter of policy, recommends that a vehicle in storage should be started once a month.
Old Mar 2, 2008 | 03:22 PM
ZeeOSix's Avatar
ZeeOSix
With today’s fuels and additives there should be no issues about carbon build-up on the valves. Use top tier fuels such as Chevron, Texaco, etc and good additives such as Techron, Redline, etc.
The main key to doing winter storage startups is to get the engine to full operating temperature. Since the C5 has the oil temperature monitor, use the DIC to ensure the oil reaches 200+ deg F before shutting the engine down.
Old Mar 2, 2008 | 03:27 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
So, without any load on the engine, could this damage it, I ponder? I run it like that once a month while it’s stored.
Any thoughts?
yeah thats so bad for any motor! revving up with no load! you need to drive the car no way around it..
Old Mar 2, 2008 | 04:20 PM
ZeeOSix's Avatar
ZeeOSix
To the guys who keep saying revving a motor with no load is going to damage it ... can you give us some technical links to back those statements up?
There is no technical way a motor held at say 3000 rpm with no load is under any more stress (it's actually under much less stress) than a motor held at 3000 rpms under heavy load.
But again, I'll say that holding any engine near redline regardless of the load isn't ideal for any motor.
Old Mar 2, 2008 | 04:25 PM
itzza427's Avatar
itzza427
Just got back to your post,and your update on your procedure scares me even more.To the best of my knowledge these motors run forged pistons.Forges pistons are fitted with very loose skirt to wall clearances because they expand much more than the weaker cast pistons.It takes a lot more than 20 or 30 seconds for the pistons to warm to the proper tolerances.In other words that kind of revving of a cold piston is beatin your piston skirts.If you've only done this a few times probably no serious harm,,But I would immediately stop this practice.1500 to 2500 will provide MORE than enough wall lubrication.That's the RPM recommendation for break in of my big blocks flat tappet cam,where most of the lubrication comes from cast off from the crank shaft.If that will cover a cam shaft it's getting plenty on cylinder walls where the pistons will distribute and coat the walls.PLEASE don't do that to a cold engine,or you'll be greeted to more progressive sound of "piston slap" in the morning.believe me I'm no timid old man,my babies are no stranger to a lead foot.My shark has been to Gateway International on test and tune nights ,just got My FRC and it'll be there as soon as they open,I gotta know what she'll do.Any questions feel free to shoot me a PM
Old Mar 2, 2008 | 04:28 PM
ZeeOSix's Avatar
ZeeOSix
I believe the OP said he doesn't rev until the engine has warmed up to near operating temps. Some reving may be good, but not to redline. I'd keep it below 3000 rpm in neutral if it was my car.
I use staybil and don’t do this revving until the engine has been at idle running long enough to reach full temps. So, without any load on the engine, could this damage it, I ponder? I run it like that once a month while it’s stored.
Old Mar 2, 2008 | 04:34 PM
itzza427's Avatar
itzza427
In post #10 it sounds as if he only ran for about 20 seconds before winging it,if thats the case the pistons are virtually stone cold,that would be hammer time fo the skirts
Old Mar 2, 2008 | 04:41 PM
  #33
ZeeOSix's Avatar
ZeeOSix
Go read it again ... I believe he's describing how he does his revving after the engine has warmed up.
On my Corvette I run the engine at maybe 2k-3K steadily for maybe 20 seconds or so. It’s after that that I do 5 or 6 high revs and let it idle for several minutes before shutting it down.
Old Mar 2, 2008 | 04:58 PM
  #34
itzza427's Avatar
itzza427
Yep,,stand corrected,,Read original post last night,checked back in today in the middle,saw the 20 second thing and got the *******!! By the way Steve, just click on the little face you want and it'll show up where ever your cursor line is
