red halltech stinger leds
The factory light housing actually has holes in the backside in the perfect spots.
It wont work if you just wire the strip into the connector by the radiator shroud. It has to be wired into the stock housing after the position switch. Here is what it takes
I followed the stock wiring route behind the hood pad down to the connector, back up under the upper radiator panel, along the t.b. cooant return hose to the throttle body side
This is how I attached the led strip to the Halltech.
:Stinger lites only when hood is opened.
This will be fun checking the oil at night
http://www.oznium.com/thin-waterproof-ribbon
