Engine swap going well
Today/tomorrow will be transferring all the item I need off of the LS1 onto the LS6 like the front and rear covers, oil pan, pick up tube, valve covers, rocker arms and all that jazz.
The new motor is a 22k mile LS6 that Vengeance Racing installed a Vindicator cam, LS2 timing chain, dual valve springs, ARP rod bolts and some other supporting goodies into. The heads are stock Z06 LS6 heads with the lightweight valves and such.
After the LS6 is in, all I will have to do is the Spec 3+ clutch, NOS system, bottle heater, purge, gauges (AFR, fuel, N2O), LT headers, hardened output shaft, DTE rear brace and I think that is all. Whew, I still have a lot of work to do...
Hopefully I'll be tearing up the streets with it by Sunday. I'm hoping for 450 to the wheels with this setup N/A. And then I'm gonna spray somewhere up to 150 on top of all that for those pesky KB Cobras and GT500's that get in the way.
A project like that would probably take me a month at best.
Sound good, hope everything goes well
Why do you not think I will see 450 rwhp?
