[Z06] Shift knob removal - C5 z06
Old Mar 5, 2008 | 05:53 PM
mikestrat's Avatar
mikestrat
Default Shift **** removal - C5 z06
I tried to remove my shift **** on my 02 Z06 in order to change the boot. After removing the cap on the top, I did not see a pin that I expected. The hole in the shift **** appears to have been modified; I assume this is an aftermarket shifter (I am not the first owner). The **** will not turn and seems very securely mounted. In the hole in the shifter there is a soft metal, also cut up, that has a threaded hole. Any thoughts about how I could remove this ****?
Old Mar 5, 2008 | 06:15 PM
wildwall's Avatar
wildwall
post a pic so we know what your trying to describe!
Old Mar 5, 2008 | 06:38 PM
01Z06 Black's Avatar
01Z06 Black
St. Jude Donor '08
Some one may have broken off the top demon key.
A pic would be good.
Old Mar 5, 2008 | 06:39 PM
mikestrat's Avatar
mikestrat
Default Picture
I don't know how to post a picture, but here is one:
http://mysite.verizon.net/vze4rsty/b...rtfromscratch/
Old Mar 5, 2008 | 06:44 PM
hotwheels57's Avatar
hotwheels57
It looks like there are still remnants of the "demon key" holding the **** securely to the lever.
If you have a set of taps/dies, you might tap some threads into the hole, insert the appropriate sized machine screw into the threads and then pry the key out with VICEGRIPS or similar.
FYI, I tried to post your image, but it's way to large when I applied the image code.
Old Mar 5, 2008 | 06:47 PM
ctusser's Avatar
ctusser
From the pic it looks like a broken key that someone tried to drill out.
Old Mar 5, 2008 | 06:50 PM
wildwall's Avatar
wildwall
That's what it looks like to me, also. Try putting a bolt in the hole. Grab the bolt with a vise grip and try to tap it up with a hammer on the vise grip.
Old Mar 5, 2008 | 07:03 PM
mikestrat's Avatar
mikestrat
Default Unsuccessful
Thanks for the advice. I had a bolt that threaded in nicely. However tapping with vicegrips and a hammer only pulled the bolt out (the metal is soft). It doesn't seem there is anything that would pull up through the ****.
Old Mar 5, 2008 | 07:06 PM
hotwheels57
You're probably going to need to cut threads into the key for a bolt to really have a grip to leverage from...
Old Mar 5, 2008 | 07:09 PM
TEXHAWK0's Avatar
TEXHAWK0
The previous owner probably tried to tap the hole to pull the key out with a bolt and never got it out. At this point your only option may be to drill out the whole key. Once you drill the main core of the key out, the rest should collapse in where you can remove it.
If it were me, I would go ahead and remove the shifter so you can work on it outside the car and do whatever you need to do without damaging anything else.
Old Mar 5, 2008 | 07:16 PM
mikestrat's Avatar
mikestrat
Default It worked!
Thanks for all of the advice. After screwing the bolt in a little further, it held and pulled the key out, which looks pretty obliterated. I won't need it anymore with the aftermarket shift **** I put on.
Thanks again!
Old Mar 5, 2008 | 07:25 PM
hotwheels57
Old Mar 5, 2008 | 08:01 PM
Quick Silver Z's Avatar
Quick Silver Z
St. Jude 15 Year Donor
No-IL Events Coordinator
2025 C6 of the Year Winner - Unmodified
2019 C6 of Year Winner (appearance mods)
2018 C6 of Year Finalist
St. Jude Donor '12 thru '26
Could this shifter stalk have been shortened (sawed off) and the tapped hole was used for keeping the stock **** in alignment?
Old Mar 5, 2008 | 08:10 PM
mikestrat's Avatar
mikestrat
The shaft doesn't appear to have been cut, based on it's length and how the threads taper at the very top.
To Shift knob removal - C5 z06
