Lights
Old Mar 6, 2008 | 05:00 PM
ztron's Avatar
ztron
Default Lights
Ok this maybe in another thread, but I need to know what led number or bulb number and maybe where to find them, for the AC unit, I have some burnt out, and also the bulb for the shifter indicator (AT).... Thanks
Old Mar 7, 2008 | 12:12 AM
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
Here's a couple of sources for the stock bulbs;
Replacement Radio/HVAC bulbs
http://www.partsexpress.com/pe/showd...number=070-105
is is a bulb that runs at 70ma. You must trim off the plastic and unsolder the lead wires, but it is the proper wattage bulb and will work just fine in both the radio and HVAC units. The illumination will match all the other indicators.
http://www.mcmaster.com/
Part number 1505K414
http://www.radioshack.com/search/ind...ulb&kwCatId=&p g=4
Part Number 272-1092..
Your Shift indicator is a 194 type bulb.
I advise that you replace ALL the bulbs at once.
Old Mar 7, 2008 | 06:47 AM
Junkman2008's Avatar
Junkman2008
Are you sure the bulbs are burned out and its not a case of cold solder joints instead?
To Lights
