[Z06] borla stingers question
Old Mar 8, 2008 | 08:46 PM
SkyWarp's Avatar
SkyWarp
Default borla stingers question
I got the dual tipped model. What is the best way to remove the borla stamped on the tips?? grind then wet sand?? I like the clean look better.
tks
Rob
Old Mar 9, 2008 | 12:03 AM
u4ick's Avatar
u4ick
Not sure you could do that with out rubbing a hole right through, the stainless isn't all that thick.
You may want to check with Borla and ask 1) how thick is the metal?and 2) how deep is the stamp?
Old Mar 9, 2008 | 12:37 AM
DPG's Avatar
DPG
St. Jude Donor '06
the borla might be stamped on and probably cant be removed. I would definitely check before you start any kind of sanding.
Old Mar 9, 2008 | 09:48 AM
Quick Silver Z's Avatar
Quick Silver Z
St. Jude 15 Year Donor
No-IL Events Coordinator
2025 C6 of the Year Winner - Unmodified
2019 C6 of Year Winner (appearance mods)
2018 C6 of Year Finalist
St. Jude Donor '12 thru '26
I believe the logo is debossed (raised) in the material and can't be removed???
To borla stingers question
