ALARM Ghost HELP!!!
Old Mar 9, 2008 | 12:19 PM
Cornfed's Avatar
Cornfed
Default ALARM Ghost HELP!!!
I have a 99 frc with the factory alarm. I am using the factory fob the fob training recognizes the fob. The fob seems to work fine at first but all by it’s self it then opens arms and locks it’s self and then it will open its self and lock back again. Not sure if it’s the fob or the alarm. The fob quits working after it does this. Fob Battery???
Ideas????
Old Mar 9, 2008 | 03:57 PM
c5streak's Avatar
c5streak
Does your fob have the "passive" slide switch. If so, you may have a bad switch in the fob. I recall a thread a while back about taking the fob apart and cleaning the contacts on the switch. Worth a try!
Old Mar 9, 2008 | 05:02 PM
Cornfed's Avatar
Cornfed
I tried that and its still acting up.
Question: the little bell looking piece that’s at the top of the circuit board has a loose piece inside it and rattles when shaken. Is that normal? I only have one fob or I would check the other.
Old Mar 9, 2008 | 05:36 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Yes, that is normal which is how the passive works. For the OP though, the passive mode is turned on in the FOB. It usually happens due to dust particles or the switch gets contaminated. Normally you can slide the switch back and forth a few times and it will clear up.
Old Mar 9, 2008 | 07:25 PM
Cornfed's Avatar
Cornfed
Nope still acting up. Could it be the alarm or a bad fob.
Old Mar 9, 2008 | 10:58 PM
Cornfed's Avatar
Cornfed
bump
Old Mar 10, 2008 | 01:58 AM
Blowndave's Avatar
Blowndave
its the fob.... mine did the same thing about 2 years ago....
Old Mar 10, 2008 | 08:35 AM
Cornfed's Avatar
Cornfed
I will get a new one.
Thanks Guys
Old Mar 10, 2008 | 10:33 PM
Cornfed's Avatar
Cornfed
New Fob and it's still acting up.
Old Mar 10, 2008 | 10:53 PM
Cornfed's Avatar
Cornfed
Were is the alarm located in the 99's so I can check the wires.
Old Mar 16, 2008 | 05:49 PM
Cornfed's Avatar
Cornfed
Bump
Old Apr 23, 2008 | 11:20 AM
Cornfed's Avatar
Cornfed
After siting all wenter it was just acting up becasue my car batt was low. Charged it full and no more issues. It took me an min to figure it out because it would start fine.
Thanks guys.
To ALARM Ghost HELP!!!
