[Z06] How do 2001Z's get 405hp?
If you guys who are asking about the differences between the 01 and 02+ Zees, do a search ... there have been many threads on this subject.
Look at post #5 in this sticky right at top of THIS forum.
http://forums.corvetteforum.com/show....php?t=1187875
ALL LSx engines (both LS1 and LS6 ) from 1997 thru 2001 are subject to oil consumption higher than GM was comfortable with. Meaning a higher % of complaints concerning oil consumption.
The conditions under which this condition resides is high RPM, light load ( like you drive in a city at 4000 plus RPM and never take it out of second gear). In that situation , the piston rings can get into a flutter condition and thats when the oil consumption can take place.
Four forces are at work in piston ring sealing; combustion PSI, ring inertia , the radial expansion pressure of the rings ( 9 pounds tension), and crankcase PSI. Ring flutter is the uncontrolled oscillation due to an imbalance from those four forces. Once a piston's rings go into flutter , they lose the ability to scrape off the oil from the cylinder walls, blow-by increases and oil consumption rises dramactically.
The combination of high RPM and low crankcase pressure, typical of low engine loads, causes those four forces to become imbalanced. The small amount of '97-'01 LS1s and LS6es that see regular , high RPM, light load operation lend the LSx engines to higher oil consumption.
Who drives around town at 4000 plus RPM at light throttle? Common sense is that sustained high speed and light load is not a normal duty cycle, even for the Corvette. After reseaching the complaints , tearing down engines and finding nothing out of specification or tolerance, it was determined that driver style was the contributing factor.
GM did , starting in the '02 model year, redesign the second scraper ring face and increased ring tension to 13 pounds. No apparent loss in power was measured from the addition of this fix.
Internet conspiracy theories, urban legend and rumor spread rapidly. While the core issue, oil use , has factual basis; it quickly became exaggerated and laced with disinformation.
As far as increasing the '01 LS6 385 hp to 405hp this can be easily done with boltons and some tuning. But the LS6 '02-'04 cam and valve train with it's .026 lift increase and lighter weight valves will give the '02-'04 the advantage when more hp is added to it. GM engineers state that the cam/valve train only adds 10 of the 20 additional hp. Adding the '02 air box and unscreening the MAF will get you 5 hp ( some have had to make slight calibration changes to the PCM).
It's been mentioned that the '02 -'04 fresh air box and unscreened MAF sensor, redesigned 1 brick CATs and elimination of the two quick light up pups ( reduces back pressure by two (2) inches of mercury and 5 1/2 pounds of weight), plus the cam and valve train, and slight changes in the fuel and spark curves was responcible for the additional 20 hp.
My 01 is bone stock and burns NO oil. (May 02 Build date ) I believe the issue was with early built 01 cars. My car has never been apart.
The extra 20HP will not show up on the street. It will arrive if you are cruising above 120 I suppose but the last time I went to Wallmart I could barely get over 40mph !
t
uhh..
Build date May 01..not 02...
what was I thinking, or..uhh..Typing !
The 2002-2004 LS6 does better from 4000 rpm up. It just breathes better but you're correct in that in a heads up race that doesn't show till high mph.
I agree! People love to dog on the 01 Z06 and label it as an oil burner or just plain damaged goods which is
I really don't see how you 2001 guys put up with these peoples sh*t. Start a petition and get them banned I say.
If your '01 doesn't use oil, then you aren't driving it correctly! Try holding it at 6200 RPM in 4th or ~142mph in 1/3 mile increments every 1minute 25 seconds in 30-minute blocks. Repeat 4-5 times a day for 2 days. If you don't "use" at least 1.5 quarts of oil your car may have more than one "dipstick". My '01 uses no oil under "normal" conditions.
I like to think of that as it's automatically adding lubrication when I need it the most.
but 02+ LS1/6 could burn oil too.My '00 burned about a quart every 2k miles but my gf's 97 C5 at 125k doesn't burn any oil.
