Fuel gauge issue?
Old Mar 10, 2008 | 02:49 PM
HOOBS's Avatar
HOOBS
Default Fuel gauge issue?
I took out the 02 zo6 this weekend after sitting for about 3 months.......I drove one way for 3 hours without any issues....till I started going home.....about 1.5 hrs into my 3hr trip I see my fuel light come on....I thought this is strange because I had 3/4 of a tank left.....I had a bit of panic....(middle of no where)....took it easy and made it to a gas station..put in $57.00..I figured if this tank was empty there is something wrong here.......After I filled up.the gauge still said empty......after driving a bit she went to 1/2 a tank then back to full....What could this be?
Old Mar 10, 2008 | 02:57 PM
02MillenniumVette's Avatar
02MillenniumVette
Your sending units are clogged up. You need to put in a bottle of Techron or Seafoam and that will clean them up. Its a common problem with the C5's.
bucwheat's Avatar
bucwheat
It's very common,I'm dealing with the problem in my 98 now.Some members say The additive Techron will help clean the sensors in about three tank fulls.I'm working on my second.I had this problem 3 yrs ago and it cured itself with Amoco whote gas.Good luck.
Old Mar 10, 2008 | 03:05 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Yeah, I agree with the others.. time for some Techron
Old Mar 10, 2008 | 04:46 PM
JH's Avatar
JH
Yup. You may need to run a couple of bottles of Techron through to clean things up a bit. Then use it twice a year to keep the fuel system clean. Also use only top tier fuels -- Chevron (which already has Techron in it) Conoco-Philips, Mobil, etc. I stay away from Shell because of its high sulphur content which contributes to the problems you are having. I never use Total--Citgo--Diamond Shamrock--Western low price brands.
Old Mar 10, 2008 | 09:14 PM
renegad44's Avatar
renegad44
From: This is not a Song, It's an Outburst: Or, The Establishment Blues; Sixto Diaz Rodriguez
Old Mar 10, 2008 | 11:06 PM
rws.1's Avatar
rws.1
1. buy a quality fule system cleaner
Shell V Power, Seafoam, Techron, Valvoline Synpower,
Berrymans Chemtool B-13, BK-44... There are several of them..
2. Buy a gasoline with an enhanced detergency package...
www.toptierfuel.com
3.If that does not work, after 2-3 tankfuls look for loose/corroded grounds.
4. If you still have a problem then you need to replace the senders.
Old Mar 10, 2008 | 11:31 PM
Give the Techron a try - it's been known to make the gauge work properly again.
Old Mar 10, 2008 | 11:44 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
If you have access to a Chevron station just use that gas, It has what you need in it, Plus it is good gas. Or use Shell.
Old Mar 11, 2008 | 01:03 AM
HOOBS's Avatar
HOOBS
WOW awesome replies gang! Thanks a million! I live in Canada and I have to look for seafoam and techron! hopefully I can buy it here! Thanks!
Old Mar 11, 2008 | 01:22 AM
clayton1's Avatar
clayton1
Banned Scam/Spammer
I used shell exclusively (no chevron) for about a year and a half without problem until about the last few months then my gauge started acting up.
Since Ive moved and been using only chevron, no prolems.
Oh, btw Im not trying to pick a fight, I just want to mention my Xperience.
Old Mar 11, 2008 | 11:10 AM
Yoggi's Avatar
Yoggi
That should help
To Fuel gauge issue?
