correct tire pressure
Old Mar 10, 2008 | 06:33 PM
brad6285's Avatar
brad6285
Default correct tire pressure
what would the correct tire pressure be for my gy gsd3. fronts are 255/35 18, rears are 285/35 18. thanx brad
Old Mar 10, 2008 | 08:08 PM
Trigger Creep's Avatar
Trigger Creep
I Forget
A long term Corvette owner told me 30 summer and 32 winter. Its worked good for me. I have 30K on the OEM runflats with 5-6/32 remaining. Lots of highway miles in there, your milage may vary.
Those redlight to redlight runs and pushing the corners until the AH screams are what eats them.
Old Mar 10, 2008 | 08:13 PM
clayton1's Avatar
clayton1
Banned Scam/Spammer
Ya, Id say around 30~psi cold.
THats what I usually keep mine around.
Old Mar 10, 2008 | 08:30 PM
brad6285's Avatar
brad6285
thanx i was thinking about 30psi
Old Mar 10, 2008 | 09:43 PM
e6bailey's Avatar
e6bailey
They put 40 psi in my tires at the dealer when I bought the car, not sure why. It seemed very high to me, the door says 30 psi if i remember correctly
Old Mar 10, 2008 | 09:46 PM
Frozenfire's Avatar
Frozenfire
As per the specs on the door jamb, I run 30 psi all the way around. On the track, I soften the rear tires a few pounds.
Old Mar 10, 2008 | 09:47 PM
waunavet's Avatar
waunavet
St. Jude Donor '20
Old Mar 10, 2008 | 10:56 PM
rws.1's Avatar
rws.1
The door says 30 psi cold.
the GS D-3's are known to lose traction in the cold
I set mine at 28 psi cold in the summer when road heat increased the pressure by 4-6 psi.
in the spring and fall when the roads are cold and the pressure doesn't change by more tha 2 psi, I set them at 30 psi
Old Mar 10, 2008 | 11:17 PM
moserbe's Avatar
moserbe
30 psi.
Old Mar 10, 2008 | 11:55 PM
Same as any other tire for the car. The sticker on the inside of the driver's door will tell you the factory recommendations.
However, I try to keep mine at 30 psi hot - which comes out to about 28 psi cold.
Old Mar 11, 2008 | 02:16 AM
Jistari's Avatar
Jistari
Depends on how cold it is. Had em all equaled out (just put 30 in them all as it says on the door) this summer but recently its been cold as a witch's . . .well cold anyway. Started getting the "Low Tire Pressur" warning on the DIC when starting out (dropped to like 24 - 26 cold), so I put a few pounds in just to stop the warning. Put them all at 29 cold now (wich would be adding like 4 lbs, yes they were all set to 30 back when it was warm out, but at 10 degrees the same amount of air only gets them up to 24, so you have to add air to get up to 29 even though they didnt leak or anything) and they heat up to about 30 - 32 in use.
To correct tire pressure
