C6 Wheels
Old Mar 11, 2008 | 08:48 AM
sledhed's Avatar
sledhed
Default C6 Wheels
Found A Set Of Non Z06 C6 Wheels (solid 5 Star) Oe 18's & 19's,
Just Wanting To Know If They Will Fit On My Stock 99 Coupe Without Spacers ?
Old Mar 11, 2008 | 09:42 AM
RRM707's Avatar
RRM707
Yes, they will fit without spacers. They will rub VERY slightly in the rear. So unless you want any wear marks, you should run a small spacer.
( I didn't, but really should have. )
Old Mar 11, 2008 | 10:15 AM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
The bolt pattern (5 x120mm) is the same. 18" and 19" wheels fit the C5 without any issues. But the issue is the offset. The front offsets are almost identical, so there is no problem there (56mm). But the back offsets are a problem - the stock C5 offset is 63mm. The C6 wheels are 79mm offset. So the issue is that the tires will rub on the chassis side of the rear fender wells.
Old Mar 11, 2008 | 02:08 PM
ljthe2nd's Avatar
ljthe2nd
If you haven't bought them yet, you can buy repro. C6 wheels that are made with C5 offsets. I bought some chrome C6 wheels from House of Wheels, a supporting vendor. They fit fine, with no issues.
Old Mar 11, 2008 | 02:31 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
should be noted that the inside area of the oem wheels are not chrome. After markets with correct offsets would be.
In my opinion the reproduction rims in the smaller c5 size 17/18 looks funny. I would make sure to go 18/19 reproduction.
If you want the oem's you can purchase 1/4" spacers from ccw wheels
Old Mar 11, 2008 | 02:35 PM
ljthe2nd's Avatar
ljthe2nd
I went with 18/19's and I think they look great.
Old Mar 11, 2008 | 03:06 PM
jserio's Avatar
jserio
O.C.
I bought a set on Ebay with the correct offset. 56mm all round and they fit great.
Old Mar 11, 2008 | 03:19 PM
ljthe2nd's Avatar
ljthe2nd
That's not the correct offset for the back, that offset on the rear might cause your wheel to stick out past the fender. The offset for the rear should be 63
Old Mar 12, 2008 | 02:14 AM
Vette Rookie's Avatar
Vette Rookie
You wouldn't have any pics available would you?
Old Mar 12, 2008 | 03:58 PM
ljthe2nd's Avatar
ljthe2nd
I've got some pics but they're huge and I don't have any way to resize them to post on here. If you want to see them send me your email address. I've got a program that will resize them when you attach them to email.
Old Mar 12, 2008 | 04:15 PM
ljthe2nd's Avatar
ljthe2nd
Here's a couple, I emailed them to myself
Old Mar 12, 2008 | 05:09 PM
Vette Rookie
Man! Those look sharp!! Now I just have to decide on those or a set of the split spoke type that comes on the new 08 model!
Tom
Old Mar 12, 2008 | 05:14 PM
ljthe2nd's Avatar
ljthe2nd
Tom
I was thinking about getting a second set of those, but in a wider wheel and tire combination than I have now. Right now I have 18/8.5 on front and 19/9.5 on the rear. If I decide to get a second set of the split spokes, I was going to go with 18/9.5 or 10 up front and 19/11 on the rear.
To C6 Wheels
