[Z06] exhaust jingle?
Old Mar 12, 2008 | 02:29 AM
pb24dagrk's Avatar
pb24dagrk
From what I remember, it sounds almost like you're dragging a light chain....it stands out even more when driving next to a concrete wall or something.
You might as well get long tube headers which come with an xpipe...that way you get awesome sound plus a great pickup in horsepower :word:
Old Mar 12, 2008 | 02:50 AM
EFNFAST's Avatar
EFNFAST
isn't it as a result of those dime-sized holes in the h-pipe?
Old Mar 12, 2008 | 08:12 AM
Max Grip's Avatar
Max Grip
My '02 does the same thing, I hear a jingle or rattle on decelleration. I can hear it when I gently rev the engine at a stop too. I think it's one of my cats, it seems to come from that area. I'm getting better at ignoring it, and I'm saving for headers...
Old Mar 12, 2008 | 09:45 AM
B-Myster's Avatar
B-Myster
It is a very common problem for the 02Z's. The jingle came from the stock H-pipe. I along with many others installed an aftermarket x-pipe and the problem went away.
Old Mar 12, 2008 | 11:41 AM
Tact's Avatar
Tact
Former Law Dawg Moderator
CF St. Jude Co-Organizer
St. Jude Donor '05 thru '24
Check out this thread:
http://forums.corvetteforum.com/show...exhaust+rattle
I've sold my '04 Z and bought a '06 Z. I got the same jingle as in the '04. I took it to the dealer and they sprayed graphite in the hangers. No more noise as of now.
Old Apr 13, 2008 | 03:23 AM
NatB's Avatar
NatB
Can't sleep - so thought I'd chime in on this -
I got my 02 Z06 in this past fall - the car was completely stock. The exhaust sounded great- at WOT it was plain aggressive. However, I had the exhaust "jingle" - which I can best describe as loose change coming from the back of the car. I too thought it might be a cat going bad - it was the H-Pipe.
Had Corvettes of Houston install a Magnaflow X-Pipe- and voila no more jingles.
But I will tell you- I very much miss the popping on deceleration and the BARK of the exhaust at WOT. So much so- that in hindsight, I probably would have put up with the jingle sound.
Now I am contemplating installing a B&B catback ( Bullets or PRTs) or a GHL Magnum system - to liven up the exhaust note.
I suppose the X-Pipe smooth out the exhaust pulse and at least in thery should enhance the exhaust flow. I kept the old GM H-Pipe, yes the hole in the H section is pathetically small ( looks like it was punched out with an ice pick).
To exhaust jingle?
