grind
Old Mar 12, 2008 | 09:57 PM
m&jincurance's Avatar
m&jincurance
5th Gear
Default grind
2002 does anybody hear a grind when they shut off the motor comming from back what is this noise?
Old Mar 12, 2008 | 09:59 PM
overBlown's Avatar
overBlown
push your clutch in. also do a search before you post.
Old Mar 12, 2008 | 10:08 PM
IrishMac's Avatar
IrishMac
Moderator Emeritus
Gone, but not Forgotten
Cruise-In 5, 6, 8 & 10 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09
Perhaps new members are unfamiliar with the Search function. Let's try to help one another.
Old Mar 13, 2008 | 12:41 AM
DefenderC5's Avatar
DefenderC5
It's the "death rattle" and it's also completely normal. If you hold your clutch in while turning off the car you won't hear it.
My guess is you are in neutral when you shut it off. You should leave it in 1st gear when the car is off, the parking brakes in the C5s aren't necessarily reliable. Just make sure the engine is stopped completely before you let out the clutch.
Old Mar 13, 2008 | 12:45 AM
e6bailey's Avatar
e6bailey
Old Mar 13, 2008 | 12:49 AM
Mariamznm's Avatar
Mariamznm
To grind
