front tires chopped up
thanks
that was my 1st thought too but I watch him do the alinement.. it was on a hunter computer machine.. it basiclly tells you what to adjust and shows on the screen as you change things and gives you a green light when it was in spec. one of the tires are cupped before the alinement on the inside so we broke the tire down and moved to the other side so the inside was fresh on both of these.. maybe I'll have to get it to put it up again before I put the new rubber on
Even worn bearings will cause cupping, especially inside cupping with a lot of hard cornering.
Strange that with good equipment, the alignment didn't correct the problem.
I'm going to need new rubber soon.. mostly due to wear on the rears..
that's why I want to find the problem with the fronts now. I've been told once a wear pattern starts on a tire it is done.. maybe they were always like this and I never noticed.. not sure
When I had my car aligned to Z06 specs, it took them about 2 hours and two drives down the street. They said the adjustments were really sensitive and when they adjusted one thing, it would throw something else out of whack.
It is a problem with the factory settings. They are aggressive for handling. If you do more straight highway driving rather than cornering, then your inside front tires will wear. This is an alignment chart posted before.
Front 97-02 C-5 Corvette Daily Driver / Advanced Street / Autocross Baseline / Track Baseline
Toe
1/32" in / 0" to 1/32" in / 1/16" in / 1/8"out-1/32" in
Camber
0° / 1/4° neg / 1/2° neg / 1/2° neg
Caster
6-7° pos 6-7° pos 4-6° pos 4-6° pos
Rear 97-02 C-5 Corvette Daily Driver / Advanced Street / Autocross Baseline / Track Baseline
Toe
1/16" in / 1/16" in / 1/16"-1/4" in / 1/8"- 1/4"in
Camber
0° / 1/2° neg / 1/4 - 2° neg / 3/4 - 2° neg
These wheel alignments are not factory standards. These are derived from tests, professional drivers and chassis engineers.
You should always consider driver, fuel and cargo weights when your Corvette is aligned. Please note that these specs are symmetrical. For example, when we recommend 1/8" toe in, that indicates 1/16" on each front wheel for a total of 1/8" total toe in.
Daily Driver - These specs are designed to minimize tire wear and dynamic forces on front end parts. Driver effort is minimum, the car will steer very "light" and may wander or be "darty" on road with wear ruts. If you are uncomfortable with this feeling, toe the car in up to a maximum of 1/8" total toe in.
Advanced Street - These specs are designed to give an even quicker steering response with minimum tire wear. If the car is "darty", toe the car in. By toeing in, you may loose some turn-in qualities gained by the initial specs.
Autocross - These specs are a good baseline to start from. The driver must take into consideration that size, compound and condition of the tires. The chassis is affected by the valve package in the shocks, spring rates and sway bars. The Autocross course design and the condition of the surface will also have a bearing. These specs do not work and are not recommended for street use because of adverse tire wear. The car will act "nervous" when ever changing street surface.
Track - These specs are by far just a baseline. Those of you who race know alignment specs will change based upon weather, track and unique setup. These specs can also change on each corner of the car and driver to driver.
