Ctek 3300 Hookup
Old Mar 15, 2008 | 06:57 PM
xlr8nflorida's Avatar
xlr8nflorida
Default Ctek 3300 Hookup
In the manual it says to only hook up positive to positive and negative to negative if the battery is out of the car. Otherwise, it says you need to ground one of the wires to the frame of the car - Is the C5 neg. grounded like most cars or positively grounded. I looked to see if I had anything coming off my battery but I didn't see anything.
Anyone have experiences with CTEK 300?
Also, they give you the wire where you can install it directly to the battery. How do you wire that up?
With my normal charger, I just hook up positive to positive and negative to negative and I'm good to go.
Thanks.
Old Mar 15, 2008 | 09:55 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Thanks.
Pull the battery surround and hook the ground to the frame. There is a factory ground there.
Old Mar 15, 2008 | 10:01 PM
robert miller's Avatar
robert miller
one of the best spots to do it.
Old Mar 15, 2008 | 11:31 PM
xlr8nflorida
Battery Surround?? Please clarify.
Old Mar 15, 2008 | 11:57 PM
FAAASTJEDI2000's Avatar
FAAASTJEDI2000
negative ground.
Old Mar 16, 2008 | 12:24 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
The plastic shroud that surounds the battery, it's removable.
To Ctek 3300 Hookup
