Lowering question
Old Mar 15, 2008 | 09:46 PM
C5Bagger's Avatar
C5Bagger
Default Lowering question
Had the front wheel off today to install fender screens, the bolt on top of the spring keeps staring at me and wont leave me alone. I know it wants me to turn it but I'm unsure which way. Could someone help as its starting to call out my name now.
Old Mar 15, 2008 | 10:36 PM
Tom Porter's Avatar
Tom Porter
If you are looking at the front bolts, turn it (counter clockwise). You are actually screwing the bushing in closer to the bottom of the upper control arm. The rear bolts: Loosen the top nut until you have 3-5 treads showing.
Old Mar 15, 2008 | 10:46 PM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
Just do it! It looks great and you will scrape WAY COOL, like me!
Old Mar 15, 2008 | 11:35 PM
Vega$Vette's Avatar
Vega$Vette
Just remember to jack up the spring itself so the bushing can turn without the weight of the Vette on it.
Old Mar 15, 2008 | 11:49 PM
Ol'55's Avatar
Ol'55
From: Southern New Jersey, The wet part at the bottom
St. Jude Donor '08-'09-'10
The rotation is as if you were loosening the bolt (removing it out the top) until it "tops out". Go ahead, you know you want to.
Old Mar 15, 2008 | 11:56 PM
SebringSixSpeed's Avatar
SebringSixSpeed
After all you did buy a Vette, not a Jeep, right?
Old Mar 15, 2008 | 11:57 PM
yaknow's Avatar
yaknow
just do it, satisfy the voices.
Old Mar 16, 2008 | 12:00 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
If it talks to you then answer it!
She'll love you for it! LOWER! LOWER! LOWERL
How low will you go!
Thanks,Matt
Old Mar 16, 2008 | 12:02 AM
madmatt9471
Here is a link to follow:
http://www.frankhunt.com/FRANK/hobbi...5_Lowering.htm
http://www.2phast.com/Corvette/lower.htm
http://www.c5forum.com/diy/lowering.php
Thanks,Matt
Old Mar 16, 2008 | 02:54 AM
andrewjhaley's Avatar
andrewjhaley
Question, should the front bolts be turned an equal amount of times, or should they be turned until they are full backed out? I lowered mine and the driver side turned 3 and 1/2 turns, the passenger side turned more than that but I matched turns with the driver sides for conformity. I have measured to the fender edge and both are equal. It just doesn't make sense to me that some people remove the bolts or cut bushings but mine are unequally turned and each side still have the same height to the fender as each other.
Old Mar 16, 2008 | 03:04 AM
SebringSixSpeed
The only true and correct way to do this is by having the wheels each on a certified scale and balancing the weight while you have someone sit in the car. But thats usually only done for racing or track cars. Most folks just run the adjusters in until they stop on the front, and back the rears out of the nuts until there are about 3 threads showing.
Old Mar 16, 2008 | 08:04 AM
cozer1's Avatar
cozer1
Hey Matt...thanks for the info Bro..i was thinking of lowring mine But now im going tooooooooo
Old Mar 16, 2008 | 10:11 AM
C5Bagger's Avatar
C5Bagger
Thanks for all the information, NOW I dont have any choice I have to lower as she was getting down to name calling last night, there way was need of that but I know how strong she feels about it now and she always always wins.
Old Mar 16, 2008 | 10:19 AM
C5Bagger's Avatar
C5Bagger
Those are some great links Matt, Thanks. Its guys like you and all that replied that makes this the number 1 Corvette forum, Thanks to everyone, Dave
Old Mar 16, 2008 | 12:27 PM
themonk's Avatar
themonk
From: Calgary, AB. There's a reason why white was the only color offered on every year Corvette. Proud Canadian German Jamaican!
St. Jude Donor '09, '12-'13-'14-'15-'16-'17
Is everything the same for 03 - 04's with mag shocks?
Old Mar 16, 2008 | 01:00 PM
SS~7's Avatar
SS~7
Just do it! ...You'll love the new look! ...
Old Mar 16, 2008 | 05:10 PM
C5Bagger's Avatar
C5Bagger
Left side is done, alot easier than I thought thanks to all the help on this forum, put the left side fender screen on so I had to pull the wheel anyway, the left rear is sitting 3/4" lower and front 1/2" and I havent even moved the car. dropped both to the stops and backed off 1/4 turn as suggested. Not going to drive until it stops snowing that is if it ever does, been a long long winter. Thanks for all the help, mayby she will let me sleep tonight.
To Lowering question
Old Mar 17, 2008 | 11:21 AM
bradleyls103's Avatar
bradleyls103
I really want to lower mine as well. The only thing I am still wondering about is if an alignment is needed. If I do each side the same number of turns from where the factory put them it shouldn’t need one??? I just hate taking my car anywhere to have anything done. I can't trust anyone!!
Old Mar 17, 2008 | 11:29 AM
OIF2XVET's Avatar
OIF2XVET
I am have a place do it but mine is getting lowered as I type this.
Old Mar 17, 2008 | 01:12 PM
hotwheels57's Avatar
hotwheels57
Get an alignment. It does take a while to fully settle. Mine continued to settle over two weeks of varied driving manners.
Chances are your car could use one with or without lowering it. The price of prematurely replacing expensive tires justifies it.
