Measuring Tire Pressure
Old Mar 16, 2008 | 06:31 AM
VETSTYL's Avatar
VETSTYL
Default Measuring Tire Pressure
Doing a little car maintenance and tire pressure is on the things to do list. A simple question that may not be that simple, when do you measure the pressure. Should the tires be warm or should the tires be cold?
Old Mar 16, 2008 | 06:36 AM
gdaddee's Avatar
gdaddee
The recomended pressure is the cold pressure.
Old Mar 16, 2008 | 06:38 AM
moserbe's Avatar
moserbe
Old Mar 16, 2008 | 06:49 AM
stig-zzz's Avatar
stig-zzz
Old Mar 16, 2008 | 06:50 AM
vetter79's Avatar
vetter79
Absolutely COLD! 30 psi all the way around.
Old Mar 16, 2008 | 09:07 AM
JimZRyd's Avatar
JimZRyd
St. Jude Donor '12
Old Mar 16, 2008 | 09:47 AM
steve8's Avatar
steve8
Always when cold.
Old Mar 16, 2008 | 10:25 AM
jrose7004's Avatar
jrose7004
Cold.
Old Mar 16, 2008 | 11:10 AM
vettman96's Avatar
vettman96
Absolutely!
Old Mar 16, 2008 | 11:24 AM
Toms2001PewterC5's Avatar
Toms2001PewterC5
I agree that cold is the correct way to measure pressure. Just wanted to share an experence I had last Wed. when checking my truck tires before a 1000 mi trip. It was 50 deg. outside and very sunny. I checked the tires on the north side ( shady) of the truck which had set out all night and they were the recommended 35 psi which is what I keep them at. Went to the south side ( sunny) and they were at 38psi for both front and back. I left them alone assuming that the direct sun light on them had increased the pressure by the 3 psi.
Old Mar 16, 2008 | 12:01 PM
Cirrus8's Avatar
Cirrus8
30 psi cold. And do not let the air out if the pressure goes up when you are driving. As the tire gets warmer, the air pressure will increase and that is normal.
Old Mar 16, 2008 | 12:09 PM
STL94LT1's Avatar
STL94LT1
The sticker on the driver's side door recommends 30 psi cold and 34 psi hot.
To Measuring Tire Pressure
