I am going to change out my spark plugs and wires tomorrow and was just wondering what spark plugs you guys were running. I was also wondering what gap I should set it at? All I have right now are longtube headers so I don't know if that makes a difference in what gap I should set it at. Thanks guys!
I beleive it depends on the actual plug you purchase. Many use the NGK TR55, which has a .55 gap. Most leave this gap as is. If you use an iridium plug, the factory gap may be different, which most leave as is.
I run headers so it's pretty easy to swap plugs, for that reason I run NGK TR55 copper core plugs and replace them every 30k or so. At under $2 per plug it's pretty cheap to do too. Oh, I run 0.060" gap on mine...
Just purchased some of these today thanks for the advice guys
