[Z06] Feedback - Super Slim HID Xenon Kit
Hey Guys,
I just got my HID conversion kit in today (5,000k) off the big auction site (supervtec). Is there any difference between this "Slim" Xenon ballast and the others being offered? Anyone have any experience with this kit?
I'll be installing the kit later on this afternoon.
Note: I am not associated with the vendor nor do I sell these. just wanted to see if anyone has had any experience with this product
I just fnished installing them and everything is working good. I only purchased the lowbeams. The headlights close and open with no hesitation or the need of flickering the high beams at all (thank god).
I used DJMotorsportAccessories instructions and followed them to a T
http://www.djmotorsportaccessories.c...tructions2.pdf
I'll see if I can take some pictures later on tonight.
Sweet...good to know I might just order my set now so when I buy a Z06 (hopefully this weekend) I will be ready to go
Edit: Ordered a set
Edit: Ordered a set
So you haven't had to flick your high's to get the lights to move up or down?? They work perfectly like stock?
Also, in your opinion, is there any point in doing the highs as well or are the HID lows bright enough?
Looks good! I like how you painted your light shrouds to match the car to
One thing, when I installed these I did them one side at a time and then tested it to see if it worked as well as stock then moved on to the other side. (I'm not using a relay harness either)
I dont think the high beams are neccessary besides if you do happen to have trouble with your HID's then the high beams can act as a fail safe.
