Whats more aerodynamic
Old Mar 17, 2008 | 06:01 PM
ZO6 Lee's Avatar
ZO6 Lee
St. Jude Donor '08-'09-'10
So I've got an ZO6 FRC: I've converted it to a Targa and removed the BSM's, but you know I don't really notice the difference in speed. Mine is scary fast, so a coupe would be ... ?
Also it's black - is red faster too?
Old Mar 17, 2008 | 06:11 PM
Kotlas's Avatar
Kotlas
No, Silver is the fastest.
Old Mar 17, 2008 | 06:21 PM
WKMCD's Avatar
WKMCD
My vert which is more closely shaped to the FRC/Z06 body than the coupe goes pretty good and I don't even have BSM's.
Old Mar 17, 2008 | 06:27 PM
fr0stb1t3's Avatar
fr0stb1t3
Actually, a more interesting question to me is:
Given that the coupe is the most aerodynamic car of the bunch, could it make a difference at the drag strip considering the speeds?
Old Mar 17, 2008 | 06:39 PM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
Originally Posted by Sigforty
The C5 coupe is more aerodynamic due to the increased slope of the back glass.
Old Mar 17, 2008 | 06:52 PM
flyzlow's Avatar
flyzlow
THE COUPE!!!
Old Mar 17, 2008 | 06:55 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
Originally Posted by zee oh six
A c5Z06 with BSM"s
Old Mar 17, 2008 | 07:59 PM
turk2gk's Avatar
turk2gk
Originally Posted by MIKE-C5
I must say you have by far the best looking c5 on the planet in my opinion including z06's(And no disrespect to z06 owners). Its just the complete c5
Old Mar 17, 2008 | 08:09 PM
marcvobx's Avatar
marcvobx
Old Mar 17, 2008 | 08:10 PM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
True because the Z's FRC top creates turbulant vorticies at high speeds resulting in severe form drag directly behind the rear window. The C5-ZO6 was designed as a track/AutoX car where high velocity takes a back seat to excellent handling and low end power.
I would say yes based on aerodynamics. Assuming you found two identical cars where the only difference was that 1 was an FRC and the other was a coupe, the coupe should win. Another question though is what's the weight difference between an FRC and a hatchback coupe.
Old Mar 17, 2008 | 08:11 PM
tlc0706's Avatar
tlc0706
Aw shucks ..I just got to the party and the question has already been answered...I knew that... ask another one..
Old Mar 17, 2008 | 08:12 PM
fr0stb1t3's Avatar
fr0stb1t3
Didn't think about that. I think if the cars are running very fast the coupe will win (talking 150mph+ runs). If they're closer to stock the weight difference would likely be more important.
Old Mar 18, 2008 | 02:00 PM
  #33
Drewstein's Avatar
Drewstein
Originally Posted by phoenixfoundmac
I also agree and that is also one of the reasons the standard coupe was repeatedly clocked at equal or higher top speeds as a Z06 despite a 55 hp deficiency in various tests. Motor trend, automobile, etc.
Why don't you list the other real reason... gearing. The shorter gears of the Z ensure it gets to a specific mph quickly, but limits it's overall top speed. Given unlimited room, the car with the taller gears will eventually pull to it's higher top speed.
Old Mar 18, 2008 | 02:04 PM
  #34
damilleniumboy's Avatar
damilleniumboy
A c5Z06 with BSM"s
and a performance hood seal.
Old Mar 18, 2008 | 02:34 PM
  #35
bucwheat's Avatar
bucwheat
How about that,didn't take long did it?
Old Mar 18, 2008 | 02:51 PM
  #36
flynbya2's Avatar
flynbya2
While it is true the c5 is more aerodynamic,I am not so sure that is the entire recipe for top speed calcs.The lower gearing of the Z will limit it's top speed as well
Also,IIRC,the weight difference between the z06 and c-5 is in the neighborhood of 80 lbs.I remember I was surprised that it was so little.Much is made of this difference,although it is there,it is not that much of an advantage to me
Not trying to **** anyone off,just an observation
