Headlight Motor Noise
Old Mar 17, 2008 | 06:17 PM
pikerunner's Avatar
pikerunner
Default Headlight Motor Noise
When I turned off my headlights this morning, the left motor continued to run even though the headlight was completely down. I had to turn the car off to get it to disengage.
Afterward, running without them on, it was fine. Just tried the lights and the same thing occurred.
Any suggestions on what the problem may be and the fix?
It is a 2000 with 67K miles.
Thanks!
Old Mar 17, 2008 | 06:19 PM
fr0stb1t3's Avatar
fr0stb1t3
Inside the housing there is a gear that controls the up and down motion of the headlight. It is made of plastic and gets ground down very easily. Eventually your headlight will not come up if you continue to let it do that without replacing them.
At the top of this section of the forum is a sticky called "weights, measurements, etc." or something like that which discusses it in length and the different people who make replacement gears.
Old Mar 17, 2008 | 06:22 PM
pikerunner's Avatar
pikerunner
Many thanks!!!
Old Mar 17, 2008 | 06:25 PM
jayindy's Avatar
jayindy
Default I just posted this in "priceless"
Support Corvetteforum!
jayindy's Avatar
Ditto, Ditto, Ditto on the forum being priceless...
...2 weeks after we had our new to us vert, our headlamp door rolled up fine, but terrible grind to close. From searching CF one member suggested taking a punch and hammer to the small metal tabs that secure the 2 housings together.
Made sense to me. The housings were simply out of alignment causing the worm gear not to mesh with the larger plastic driven gear.
My lovely wife held the housing (she is a trusting soul) and I wack'd the tabs with a large punch and hammer. The headlamp then rolled down perfectly thus putting a big grind on both of our faces..thanks forum! (total cost $0, at least for the moment
Old Mar 17, 2008 | 06:45 PM
Oldvetter's Avatar
Oldvetter
jayindy's Avatar
Nope, sorry your gear was bad. The gear only goes bad in two places, full up and full down. What happens is that the headlight module uses a current sensing circuit to stop the headlight motor when it hits the stops (both up and down). You see, when the motor hits the stops it trys to keep turning, putting pressure on the gear and increasing the current. When the circuit senses this increase in current it turns off the motor. BUT, the motor gear is metal and the headlight gear is plastic, over time the metal gear grinds down the plastic gear and then you get no current surge. There appears to be a timing cycle which will turn off the motor, but after some grinding.
To fix this you can move the gear 90 degrees, so you have new sections or replace with a brass gear.
What you did by changing your stops is to use a new section of the gear. You also made your headlight alignment off slightly and if you did this to the driver's side headlight, you may find that popping back up soon. If so, bend the stops back and fix the gears correctly.
Old Mar 17, 2008 | 07:04 PM
Jet-Jock's Avatar
Jet-Jock
Stickies were moved to the top of Tech/Performance.
Yep it won't last long once it starts making that noise and running on after the headlamp is down or up.
Replace the motor or remove existing and rebuild.
It absolutely blows me away that after a full generation run, C4 1983-1996 that Chevy engineers choose to use the exact same motor on the C5 to drive the headlamps. After all these years of knowing that the way they were designed and the materials used that they failed every few years. Yet used them anyway.
Probably when Dave says it was the hardest decision we had to make on the C6 to remove the flip up headlights what he meant was our engineers are absolutely stumped and cannot come up with any other design without using the same failing motor, well we just gave up and made the decision to get rid of the flip headlights and went with fixed ones.
If you have small hands, you can remove the lamp top cover and bezel, unplug the motor, remove the three bolts and one nut, and lift the motor out. Rebuild or replace. Takes about an hour per lamp.
More importantly, if this one is going the other will be right behind it within a few months.
Been there done that on the last three vettes!
Old Mar 17, 2008 | 07:07 PM
fr0stb1t3's Avatar
fr0stb1t3
It absolutely blows me away that after a full generation run, C4 1983-1996 that Chevy engineers choose to use the exact same motor on the C5 to drive the headlamps. After all these years of knowing that the way they were designed and the materials used that they failed ever few years. Yet used them anyway.
If you have small hands, you can remove the lamp top cover, unplug the motor, remove the three bolts and one nut, and lift the motor out. Rebuild or replace. Takes about an hour per lamp.
There's still one sticky on top and it has the answer as well.
And you don't necessarily have to have small hands, mine are pretty big and I did it with a scrape or two :P
To Headlight Motor Noise
