Wheel decals. Can you remove them?
Old Mar 17, 2008 | 09:54 PM
mbroadway's Avatar
mbroadway
Default Wheel decals. Can you remove them?
The previous owner put some decals or tape on the polished aluminum wheels. From a distance it looks like the word "CORVETTE" is engraved in red in one of the spokes. But up close it's obvious that it isn't. It appears to be a clear tape with the "CORVETTE" in red type.
My question is: Can this tape be removed and will it leave an obvious mark on the spoke that it's on? I'm wondering if the spoke will be a lot shinier in that retangular area where the tape has been living. If so, it might be wiser just to leave it on and not worry about it.
Any ideas?
Thanks.
Michael
Old Mar 17, 2008 | 10:07 PM
dobewillie's Avatar
dobewillie
if it is tape pretty sure it will come off and clean up just fine
Old Mar 17, 2008 | 10:33 PM
doje's Avatar
doje
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
All depends on what kind of tape and how long it has been there. Unfortunately there is no way of knowing without actually removing it.
Old Mar 17, 2008 | 11:47 PM
jdmvette's Avatar
jdmvette
Night Owl for life
peel it off and use a can of goof-off to remove the residue.
Old Mar 18, 2008 | 06:49 AM
HMannini's Avatar
HMannini
Cruise-In X Veteran
St. Jude Donor '09
Epoxy Paint Remover works like magic, just paint it on and a few minutes later wipe the logos off. They literally melt and it doesn't bother the finish on the wheel.
Old Mar 18, 2008 | 07:15 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Take a hairdryer and warm them up and they should peel off!
Thanks,Matt
Old Mar 18, 2008 | 09:57 AM
B-Vette's Avatar
B-Vette
GM's "Tar & Oil Remover" is excellent for removing glue and not hurting painted surface as well.
Old Mar 18, 2008 | 10:19 AM
zwaldo's Avatar
zwaldo
what happened to using the good old finger nail method....
Old Mar 18, 2008 | 10:43 AM
ZO6 Lee's Avatar
ZO6 Lee
St. Jude Donor '08-'09-'10
Any of the above ideas will work. And I think the wheels will look way better without. Good luck.
Old Mar 18, 2008 | 10:47 AM
bucwheat's Avatar
bucwheat
I have the red letters on my spokes and they look awesome.
Old Mar 18, 2008 | 06:33 PM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
Car wash and use the high speed pressure hose
Old Mar 18, 2008 | 10:59 PM
If it is just tape, try heating it up with a hair dryer and then gently use your fingernail to lift the decal off.
To Wheel decals. Can you remove them?
