[Z06] help with tail light bulbs...
Old Mar 18, 2008 | 01:13 AM
pb24dagrk's Avatar
pb24dagrk
Default help with tail light bulbs...
One of my bulbs went out. It turns on when i hit the brakes, and when I put on my blinkers...but under normal driving with the headlights on, it stays off
it's the far left tail light
simple fix that I can do or what? Can't find anything online
Old Mar 18, 2008 | 01:26 AM
mqqn's Avatar
mqqn
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05-'06-'07-'11
Hi pb24dagrk -
That is a two-filament bulb (I want to say an 1157 but I am not 100% on that). The "constant burn" filament is burned out I would guess.
You'll need a t-15 torx to remove the two bolts holding in the taillight housing.
The bulb just twists out and you remove the connector.
best regards -
mqqn
Old Mar 18, 2008 | 08:25 PM
CJR2's Avatar
CJR2
St. Jude Donor '08
You can get them at your local auto-parts store for about $3 a pair. Replace both sides as the always go out in pairs.
Old Mar 18, 2008 | 09:59 PM
pb24dagrk's Avatar
pb24dagrk
is this correct?
http://www.trademotion.com/partlocat...layCatalogid=0
Old Mar 18, 2008 | 10:34 PM
CJR2's Avatar
CJR2
St. Jude Donor '08
Originally Posted by pb24dagrk
Yes but just go to your local Autozone or Pepboys and they will help you out and may even help you install them if they aren't busy. I use Phillips bulbs for all my cars. Great quality and price.
Old Mar 18, 2008 | 10:41 PM
pb24dagrk's Avatar
pb24dagrk
OK, thanks for the help. I'll stop by later this week.
Just curious, how come the brake light and turn signal works, but the lamp doesn't light up otherwise?
Old Mar 18, 2008 | 10:48 PM
CJR2's Avatar
CJR2
St. Jude Donor '08
Originally Posted by mqqn
Hi pb24dagrk -
best regards -
mqqn
As he said, the bulb has two filaments, one filament is burned out, the other is fine. Blinkers are covered by a seperate bulb.
To help with tail light bulbs...
