Right now I have a '91 coupe. I installed an aftermarket Pioneer radio and immediately got the "SYS" light flashing. My question: Does the C5 we're buying with the stock bose system incl. 12-disc changer allow me to change out the radio without any type of electrical code "warnings" such as the SYS in our C4?
I've seen numerous postings about installing a 2x din radio. Will an ordinary single din work?
Thank you.
Glen
Do a search in the audio section and you will become very well informed about your question and plans. A ton of information has been documented on this topic including part numbers for the harnesses required. Good Luck and Enjoy!
Thank you for the responses. I did go to the audio section, but to be truthful those folks are waaaay out of my league! I couldn't tell "Head unit" from a Head Bolt. Seriously, I just like to listen to a little old fashioned rock and roll periodically and an inexpensive system would probably be great for me.
Thanks again.
Glen
