Ok, so this is ridiculous... I lowered my car at the end of last year and the time has come for new wheels and tires. How do I even begin to jack this thing up. Ive done it before but I'm not sure if its lower now or Ive forgotten how. Any good recommendations as to how to get this done without screwing up the car would be greatly appreciated! Also wondering if any of you guys have gotten your cars inspected since you lowered yours because I'm nervous about that situation too. Thanks for the help!
Drive up on some 2x4's and the you should be able to get a jack under it. Where are you located? Just curious as to why you would need to get your car inspected since its lowered.
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
2x4s and jacking pucks. I live in Texas and had no problem with inspection.
I used to drive onto a little piece of 2x4 scrap with the left front wheel. Then I go around to the back and jack the rear end up and put on jackstands(otherwise, my jack wouldn't be able to fit back under with the front in the air) At this point, there should be enough room to jack the front up...but I place the jack between the front of the door and side vent on the front fender. I jack it up just enough to get a small jackstand on the frame rail...so its resting on the 2 rear jackstands, the right front wheel on the ground, and the last jackstand underneath the left door area. Slip the jack under the car and jack it up on the front crossmember....thats the only way I could do it with a standard 2ton floor jack
That's exactly what I do. I have a 2x4 that's maybe 12" in length just to drive up on. Then there's plenty of room to slide a jack in to get started.
I also have another question, who did your alignment after you lowered them. I had pep boys do it... the wear on my tires was bad. had threads showing on the inside tread and about 1/6 of an inch on the outside. i guess that would be the camber angle but are those adjustable?
lowering increases negative camber, and will wear the tires out on the inside. and camber is adjustable.
From: The line waiting to see Santa Claus stretched all the way back to Terre Haute, and I was at the end, Indiana
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
My 99 is lowered with suspension AND on bolts. There is 3-1/8" clearance under the rocker, and I looked everywhere for a jack with 3" or less clearance. I finally found one at Harbor Freight that I could get under my car. It works great with pucks and is light enough to move around the garage easily. If you need help lifting, use lumber. I have a few pieces of 2x8 cut about 18" long that I drive on.
Here's info on the jack. http://www.harborfreight.com/cpi/cta...emnumber=91039
