Radio Security LOC
Old Mar 20, 2008 | 09:57 PM
bryan j's Avatar
bryan j
8th Gear
Default Radio Security LOC
Anybody know how to unlock the radio after disconnecting / reconnecting the battery? I bought my first vette last fall (O4 CE vert, M6) and after taking it out of storage tonight, I reconnected the battery and now my radio is locked. I bought the car used, and didn't reset the code before disconnecting the battery, and of course I have no idea what the previous owner's code was. The owner's manual says to take it to the dealer, but I thought I'd check in with some forum members first.
Being a real man, I decided to read the manual only after I screwed up!
Old Mar 20, 2008 | 10:07 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
From another thread:
The following procedure will give you a new code that you can use instead of your personal code. Using this new code, you can ?unlock? your radio and then ?re-lock? it with a new code if you wish. Prerequisites: The radio must be in LOC mode NOT in INOP mode. Let me explain. If you have activated the Theft-Deterrent feature of your radio and loose power, the radio goes into LOC (theftlock) mode. With the ignition on, you must use the MN and HR buttons to enter you personal code in order to unlock it (The instructions are on page 3-27 in your Y2K Owner?s manual). If you fail to enter the correct code eight (8) times, the radio goes into INOP mode. You have to wait an hour with the ignition on before the radio returns to LOC mode (go for a long drive somewhere). Procedure:
01. Turn the ignition ON (The radio displays LOC)
02. Hold down the Radio Presets 2 and 3 buttons for six seconds
03. The radio display changes from LOC to a three-digit number. Write this number down. Don?t take forever, fifteen seconds max before the next step.
04. Press the AM/FM button
05. The radio display changes to another three-digit number. Write this number to the right of the first one.
06. You now have a six-digit number, the first three digits are from STEP 03 and the last three digits are form STEP 05
07. Call 1 800 537 5140
08. Press 1 then # (pound). You?ll hear ?Invalid Code, try again?
09. Press 139010 then # (pound). You will be asked to enter your four or six digit code followed by * (start)
10. Enter the number from STEP 6 then * (star)
11. Listen to the four-digit number and write it down. It will be repeated twice
12. Turn the ignition ON (The radio displays LOC)
13. Use the MN and HR buttons to enter the code from STEP 11
14. Press the AM/FM button. The radio display changes to SEC Your radio is now ?un-locked? and usable. The Theft-Deterrent feature is STILL active! If you want to disable it, use the instruction on page 3-27 in your Y2K Owner?s manual. Use the code from STEP 11 instead of your personal code.
Note: This tip originated from LOTZAHP, Austin TX (credit must be given where credit is due). I verified it on an Y2K C5 with a locked radio - mine.
Old Mar 20, 2008 | 10:43 PM
bryan j's Avatar
bryan j
8th Gear
Thanks!!
Old Mar 21, 2008 | 12:14 PM
jld04z06's Avatar
jld04z06
I have a 04 z06 and my radio doe display LOC. I can get the first three digits of the code. However, when I hit the am/fm button for the second set of codes nothing happens? Does anyone have a idea of what is wrong or what else I can try? Thanks for the help.
To Radio Security LOC
