RAISING a Vette
Old Mar 21, 2008 | 12:37 PM
pmuney's Avatar
pmuney
Default RAISING a Vette
I know everyone wants to lower the vette. But If I raised the stock bolts all the way up (No i dont even know what that means But I assume you twist some bolts farther out of the suspension raising the car). Would it give me a significant increase in height? There is one speed bump at work I scrape everyday and have no way around, I really only need about 1/4 Inch or something, but If I raised it as far as possible maybe I could Even use a couple more sets of ramps. Also wouldnt I get a smoother ride?
Old Mar 21, 2008 | 04:36 PM
98 driver's Avatar
98 driver
2nd Gear
Default raising your vette
I had to have my 98 front end aligned about 2 years ago at a dealer that sells a lot of vettes. The aligner raised milne about 3/8ths of an inch during the alignment at no extra charge. Not sure how he did it but it has held and the alignment seems fine.
Old Mar 21, 2008 | 05:20 PM
AC54ME's Avatar
AC54ME
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
I believe it takes four (4) full turns to raise/lower 1/4".
Old Mar 21, 2008 | 05:35 PM
YELLOHHH's Avatar
YELLOHHH
You bought the wrong car.
To RAISING a Vette
