Clutch Fluid Replacement
(http://www.rangeracceleration.com/Clutch_Care.html)
Storms all afternoon. Being in construction, when it rains, usually we get shut down. So I had the afternoon off. Decided to change my clutch fluid, and install the Killer Bee.Here is the clutch fluid change:
All of the stuff needed. DOT 4 brake and clutch fluid(I used NAPA brand), Baster, Rags, and empty water bottle for the old fluid.
I started out by laying rags around the clutch fluid reservoir, as the fluid is corrosive, and the process can be messy.
This is the color of the fluid, after 781 really fun miles in the new Z.
Suck all of the old fluid out with the baster. And be careful, the baster likes to drip a little of the fluid out. Next time, I’ll use a automotive syringe, which is on my list of things to get from Autozone, to lessen the droplets.
Clean out the reservoir with a lint free rag.
Fill with fresh fluid. Fill to about half way between the ‘min’ and ‘max’ marks.
Clean the cap, and replace.
Pump the clutch pedal about 20 to 30 times, and check again. Mine was dark again. Not as dark, but not clear.
So I repeated the process, 3 times in all, and ended up with this.
Like new. A LOT of people swear by this method, to avoid clutch pedal issues. It really only took about 15 minutes, even while shooting the pics. I think it is really good, and easy ‘preventative’ maintenance.
PS. Like I stated earlier, the turkey baster likes to drip a little, so I’m gonna try a large syringe next time.
:z:
I need to look at doing mine soon and was wandering if you can upgrade from the standard fluid to a higher rating D0T 4 or 5 or 5.1by using the above method. I know certain fluids do not mix but cannot remember which.
Just wondering what everyone else has done.
I don't think the dot 5 is recommended.
I plan on doing mine soon with dot 4.
New fluid on the left, old on the right.
My 98 Chev pickup with a five speed had a problem disengaging the clutch about a year ago. I was ready to buy the throwout bearing asssembly (it's one enclosed unit) and took a look at my c/fluid reservoir...yuck...black and grimy.
I opened the bleeder below and let gravity pull the fluid out while keeping it filled up a above. Finally it cleared up down below, I closed the bleeder, pumped the clutch pedal a few times....bled some more goo out and VOILA....my clutch started working right again and has ever since.
Can I do the same with my Corvette? I'll have to look during my next oil change if nobody answers here. I agree, I think it's better to bleed it all the way through. However, as said, this baster idea is better than ignoring it!!
As far as I am aware this was the original fluid from 2003...
I am still changing it every couple of days as it keeps turning black but not as bad. I will continue to do so until it runs clear.
And to the person who stated that this is a bad idea and to bleed it from the bottom only...
Yeah...ok ...its no replacement but it sure as hell is a good idea to do this as well.
Point being as much off a mess as my fluid is/was I would have needed multiple full bleeds
Also, TURKEY BASTER sucks! it drips and leaks, find a big syringe if you can. Also trade up to Synthetic DOT4, better heat and compression #'s.
I traded up in both the clutch and the brakes to the syn Dot4.
