[Z06] tq specs
Old Mar 23, 2008 | 07:59 PM
Kurtomac's Avatar
Kurtomac
Default tq specs
ready to do my header install, tranny fluid change, rear end fluid change and bleed slave...need tq specs
header to head bold tq specs, 02 sensor specs, clamp specs, rear bolts from xpipe to catback specs, hanger specs, tunnel plate specs(im going to bleed my slave), slave bleeder bolt specs, plug specs, air tube specs, trans bolt specs top and bottom, rear end bolt specs top and bottom....any other that you guys can think of specs
wish me luck on the install...LG pros catless X pipe...will i need to tuck the rear 02 sockets up above the tunnel plate?
Old Mar 23, 2008 | 08:11 PM
hotwheels57's Avatar
hotwheels57
http://www.eliteengineeringusa.com/C5_Torque_Values.pdf
