courtesy light relay?
Old Mar 23, 2008 | 09:32 PM
z28flash's Avatar
z28flash
Default courtesy light relay?
I was working on replacing the courtesy floor lamp with my LED and cut both wires at the same time while live.
Only thing I could find was the relay (position number 42 in the fuse box). Is there a fuse I missed? Otherwise I'll just replace the relay.
Thanks!
Old Mar 24, 2008 | 11:49 AM
BaileyD's Avatar
BaileyD
Try checking fuse #26 I think in the passenger footwell it is the same fuse as the com2 port under the steering wheel as it supplies power to both the lights and the com2 port.
Old Mar 24, 2008 | 11:52 AM
z28flash's Avatar
z28flash
Thanks, I'll check that this evening. The stealer wanted $109 just to diagnose the issue...but they did say if it was "simple" they would only charge $55...nice of them
I really didn't see it being the relay, as I think that is more for the timer delay...but I didn't see the fuse listed, though I think I heard it pop when I cut the wires. I'll find out tonight!
Old Mar 24, 2008 | 12:05 PM
BaileyD's Avatar
BaileyD
Just double checked thsi is what you want Check IP Fuse C/LALDL FUSE#29 10 amp.
I lost my interior lights and this fuse was out.
Old Mar 24, 2008 | 01:26 PM
z28flash's Avatar
z28flash
Thanks...they just couldn't name it something easy could they? lol
Old Mar 24, 2008 | 04:14 PM
BaileyD's Avatar
BaileyD
That would be to easy
Hope it turns out to be your problem.
Old May 30, 2008 | 08:23 PM
minitech's Avatar
minitech
I just did the same thing with my footwell lights. While soldering the two touched and now footwells out.
Anyone have info on which fuse it is. Not clear at all in the manual.
Old May 30, 2008 | 08:53 PM
minitech's Avatar
minitech
It was fuse #29.
To courtesy light relay?
