Custom Projector Headlights (revisited)
#41
Former Vendor
St. Jude Donor '08
When I finish them, I'll start a new thread with an overall summary and schematics. There are a few things that I could have done to make the project much easier if i had the proper tools.
For example, I would have ordered a sheet of 1/8" Aluminum and used a band saw to cut it, and fold it so that the headlight frame would be a single solid piece. Then I would have the edges tig welded. Nearly a week and a half was spend on trying to bond galvanized steel plates. This idea would have made fiberglassing significantly easier as well.
I have a friend in my corvette group that works at a body shop. I'm going to see if i can convince him to help me paint the fiberglass. I'd hate to put all this work into a project and have the paint look like poo.
#43
Former Vendor
St. Jude Donor '08
non pop up headlights cost nearly $250-300 for the main lenses alone! The cost of my project since the beginning was only ~$400. The catch here is that to build non-pop up headlights (which would be MUCH easier) would require the use of smaller projectors such as the Hella 50mm modules. Unfortionatly there is no halogen model for the High beams so your cost goes up dramatically:
Lens: $250
Low beams: :$243
High beam (xenon): $812
Low beam D2S xenon conversion: $120
that's over $1425 in optics alone!
add the cost of hardware, and the dookey smooth angel eyes, fiberglass and misc stuff and you're easily looking at $1500 for headlights...granted they would be the coolest headlights around, but I'll drop 1500 in the engine before I throw it at headlights.
Lens: $250
Low beams: :$243
#44
Lens: $250
Low beams: :$243
Lens: $250
Low beams: :$243
#45
Former Vendor
St. Jude Donor '08
Why not just use the same lamp for high and low beam? Since the low beam would be HID, you really wouldn't need the high beams all that often, and if you use them for high beam as well without cancelling the low beam, you would have plenty of light and save $449 in parts off the bat.
#48
Former Vendor
St. Jude Donor '08
I spent the last couple of days sanding, re-glassing and sanding some more. The shape of the curve doesn't lend itself well to power sanding so it all had to be done by hand: 80gr, 120, 220gr, 360gr. Fun stuff but I got a good arm workout
I dropped them off at a friend's body shop for finishing/painting. I will start another thread to summarize the build log once they're finished/mounted.
#51
Former Vendor
St. Jude Donor '08
I've decided to make this thread the "master thread" but if you want to see the cliffnotes look here:
http://forums.corvetteforum.com/show...post1565285302
Here are All the pics for the final installation:
Back from the paint shop:
Installed:
The halos look awesome:
Headlights On:
Night Shot:
The back side:
Paint kudos go to Brocks Collision Repair. My Buddy Larry hooked me up with their in-house painter.
Installed:
Headlights On:
Night Shot:
The back side:
