Hey guys, so i drive an 02 c5z with 32,000 miles, only mods are a vararam intake and the plug n play hids. Last night my check engine light came on and stayed on, no flashing. Came home, pulled the codes, and these are what i got..... P0171 - Fuel trim system lean bank 1, P1431 - Fuel level sensor 2 circuit performance, B2282 - Battery #1 fault dcm - left, B2284 - Battery #2 fault dcm - left, B2283 - Battery #1 fault dcm - right, B2285 - Battery #2 fault dcm - right, U1064 - Loss of communication with dcm (no soh message recieved-rfa........ i understand the fuel level sensor because my gas guage has been messed up and reading wrong and im tryin to do the fix with techron right now but can you guys help me figure out what might have caused all the rest of these codes????? oh and they all had an H next to them for history. Any help would be much appriciated, thanks!
while i was going through all the codes i tried hitting the reset button but it didnt clear anything. i read it straight from this part of the sight https://www.corvetteforum.com/techti...D=26&TopicID=1 but it didnt seem to work, maybe i was doin it wrong....any help?
I get the U1064 all the time too. I read somewhere about a wire in the door that rubs through. Will check it out this weekend.
Uxxxx codes are common in a C5, they indicate one computer was unable to talk to another at the moment in time it wanted to. Since the data bus is relatively slow (about the speed of a dial-up connection) these glitches do occur.
Unless you have some other symptom indicating a problem, delete Uxxxx codes and ignore theem.
Alright i got them deleted and nothing has come back up yet, cel is off and everything seems right. you do have to hold down the reset button for about 3 seconds for it to clear the codes..... thanks guys!
