Torque Converters/Stall converters
Thanks.
At engine idle the torque conveter has a set rpm that , in general term dissengages the transmission of power , like pushing the clutch in. When the engine throttle is pressed and engine rpm rises to the designed rpm the fluid is thrown against these vanes and transfers power to the tranny and ultimately the rear wheels and you move.
This is the most basic I can get. But like your own car you need only a little increase in rpm to start your car moving. To low a stall and the engine dies , like not pushing in the clutch when coming to a stop. Or to high a stall rpm or stall speed reving the engine rpm and 'popping' the clutch.
Race cars or drag cars inparticular have a different purpose than you mom's sedan.
The term stall describes that pre deterimed or designed rpm when the fluid engages the vanes and begins to transfer power with the tranny in gear and the brakes locked.
Now a hi performance stall converter is designed with a higher rpm to take advantage to the best hp/torque to launch a particular car . Just as you would rev the engine with a clutch before leaving the starting line to maximize the power your engine developes.
Your passenger car converter stall is probably between 1200 -1600 rpm . Where a stall convert will be 2500-3000 rpm and up depending on many factors . This is basilcy determined by many factors including engine , differential ratio, transmission, total weight of the car.
I'm not a teacher but thats a nut shell, I'm sure the internet or other will clearify and be more specific.
that pretty well nails it!when camshafts with mega lifts/overlaps, carburetors with large diameter venturies, and headers with large diameter primary tubes are combined you get a great recipe for top end horsepower and torque but you get killed on the bottom end. to raise the launch rpm into a more useable range a higher stall converter is used. for everyday driving the stall converter causes the sensation that the transmission is slipping on take off, more heat is generated in the fluid, and fuel mileage suffers.
todays roller cam profiles and electronic fuel management systems lessen somewhat the effect on driveability unless gone to extremes.
You've left out the added mechanical advantage the converter gives (and maybe you left that out intentionally - part of your basic description). This is the "STR" value given to converters.
The stall value is when (RPM) the automatic clutch grabs; the STR value is the mechanical advantage the converter provides at lower RPM's (then slowly takes it away as RPM rises).
But there are trade-offs. Obviously with rpm, the higher you start to go the better the potential performance if you have the right tires/traction. But the car will become looser/sloppier at low speeds before the converter locks.
As for STR, a higher STR will be tighter as well as perform a better launch, but the lower STR will be looser and will be more efficient all the way down the track.
I personally have a Vigilante that flashes to 3200 rpm and has an STR of 2.5
It is a little loose but bearable. I would suggest finding one to test drive if you plan on a 3000rpm or higher converter. Some people say they drive like stock, but different folks have different tolerances. I would not recommend my converter to anyone with 3.42 gears or milder without a test drive first.
I'm more interested in roadracing/autoX and I know I really need a manual transmission, but that will come in time. How detrimental will a higher stall converter be in those types of races?
