[Z06] Help - What Part Number Is This ?
It is the outter black molding 1 piece that runs along the window frame on thru the sides of the windshield.
Note: Not The Internal Weather stripping
Thank You
Let me guess, yours is cracked vertically. They all do eventually... the dealer will have the part number and it's cheap as well. Here's the rub, replacing it is probably going to cause a leak - assuming you didn't have one to start with - unless the person who does it is VERY careful to make sure they have a good seal. Do a search and you'll find plenty of info on the leak situation, and perhaps the part number as well if you really want to know it before you call the dealer.
Well its good to hear that its not that expensive I just wanted to know the part # so that maybe I could order it online from www.GMPartshouse.com
Does anyone you know if this is the correct part?
http://www.trademotion.com/partlocat...layCatalogid=0
Thank You
dealership is telling me that I need plastic retainers that are supposedly gonna cost me $80 each
