Code Help? P1416
Old Mar 28, 2008 | 09:36 AM
redroc's Avatar
redroc
Default Code Help? P1416
Guys
How do I fix this code, I know it is air bank #2, which I assume is a sensor, but can someone advice?
Thanks,
Tara
Old Mar 28, 2008 | 12:38 PM
TM-Z06's Avatar
TM-Z06
The check-valve in the AIR tube is probably clogged:
http://forums.corvetteforum.com/show....php?t=1955977
Old Mar 28, 2008 | 12:40 PM
bucwheat's Avatar
bucwheat
Bump bump
Old Mar 28, 2008 | 04:26 PM
harper615_2's Avatar
harper615_2
5th Gear
Mine was throwing the same code and the check engine light is on. Dropped it off at the dealer this morning, and they said +- $500 to repair. They also said the intake has to be pulled. Is that true?
Old Mar 28, 2008 | 10:03 PM
RonJ's Avatar
RonJ
Originally Posted by redroc
Guys
Thanks,
Tara
The check valve can often be cleaned by using a carb cleaner down the hose, let it sit 15 minutes or so, use compressed air to blow it through and re-connect your plumbing. Solved my problem 100%, no light in over a year!
RonJ ...
Old Apr 6, 2008 | 02:39 PM
redroc's Avatar
redroc
Ron
Can you tell me how to do the method that you did and hopefully i will get the same result...
Thanks a million,
Tara
Old Apr 6, 2008 | 03:36 PM
Mac11's Avatar
Mac11
Here, try this BC fix with pics !
http://forums.corvetteforum.com/show....php?t=1626660
Old Apr 6, 2008 | 08:45 PM
RonJ's Avatar
RonJ
Originally Posted by Mac11
This is an excellent write-up Redroc, I sent you an email too. Good luck!
RonJ ...
To Code Help? P1416
