Brighter BackUp Lights ! Lots a Pics
Old Mar 28, 2008 | 06:43 PM
jrprich's Avatar
jrprich
Default Brighter BackUp Lights ! Lots a Pics
Following the lead of RadioFlyer I decided that since I had the parts I would change out my lame OEM Back Up Bulbs and install headlight bulbs in the stamped steel sockets that I had left over from my attempt at a HID Projector modification.
If you want to do this mod, it is very easy, IF you have the OEM stamped steel sockets.........
Step one, remove the license frame and the plastic backup light frame and clean up the site
Lay out your parts and tools
Notch the OEM stamped steel light socket to accept the OEM lamp mount so that the process is reversible. I used a cut off wheel on my angle grinder........quick cut
Use silicone seal to glue the bulb mounts to the OEM socket....again, allows a reversible install. I then taped them down and let dry overnight.
Splice in an OEM pigtail to accept the 9005/9006 bulbs. Got these on ebay, but most auto parts houses have them as well. Again I leave the OEM bulb sockets in place if I decide to reverse the mod.
Taped up the OEM connector to keep out water
Done, repeat on the other side and reinstall
Overall the improvement is very large in the brightness of light available out of the stock BU reflectors.
Old Mar 28, 2008 | 06:44 PM
damilleniumboy's Avatar
damilleniumboy
mmm, night shots...
Old Mar 28, 2008 | 07:43 PM
Nick1's Avatar
Nick1
I like the concept, and I'm sure it's bright, but isn't that a lot of additional wattage and heat? How is it holding up? I guess they are not on for long periods which may make it work out alright.
Old Mar 28, 2008 | 07:58 PM
Z06-JIM's Avatar
Z06-JIM
Cruise-In VII Veteran
Nice job... ...I'm sure night shots would show a big improvement...
Old Mar 28, 2008 | 09:19 PM
jrprich's Avatar
jrprich
As you mention, BU lights are not on for long at a given time.
So far no issues at all
Old Mar 28, 2008 | 09:21 PM
jrprich's Avatar
jrprich
I will take some night shots......once it stops snowing here
But I didn't take the time to do a old vs new photo shoot at night, so I doubt the shots will show much
Old Mar 28, 2008 | 09:23 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
Very nice mod you have done and would like to see a night shot
Old Mar 28, 2008 | 10:38 PM
Sportsdude's Avatar
Sportsdude
Nice mod
Old Mar 28, 2008 | 10:43 PM
Junkman2008's Avatar
Junkman2008
Dammit Jim, I thought I was done fooling with my lights!!!
Nice job, very professional looking which you know is a must for me. Oh well, I'll just add it to the list.
Old Mar 28, 2008 | 10:51 PM
IDM's Avatar
IDM
or just buy the led bulb that fits right into the oem socket??
Old Mar 28, 2008 | 11:13 PM
Thanks for the informative write-up.
Old Mar 28, 2008 | 11:16 PM
jdmvette's Avatar
jdmvette
Night Owl for life
i guess 9006 halogens are good for something after all!
Old Mar 28, 2008 | 11:18 PM
jrprich's Avatar
jrprich
Guess so,
I started to put in my Toshiba HIR 9011s..........maybe I still will.
Old Mar 28, 2008 | 11:19 PM
jrprich's Avatar
jrprich
Good luck finding an LED that is anywhere close to as bright as a 9000 series halogen
Old Mar 28, 2008 | 11:21 PM
jrprich's Avatar
jrprich
Problem is finding the stamped steel bulb sockets.......I have no idea where you will find these.
Old Mar 29, 2008 | 12:04 AM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
I'm starting to think we think alike...
however I believe i have your but whipped:
http://forums.corvetteforum.com/show....php?t=1981371
Imitation is the best complement
Old Mar 29, 2008 | 12:06 AM
camvette91's Avatar
camvette91
Cool. Keep us posted with night pictures.
To Brighter BackUp Lights ! Lots a Pics
Old Mar 29, 2008 | 02:11 AM
C5R USA's Avatar
C5R USA
From: Ideals are peaceful...History is violent...St.Charles, MO.
C5 of Year Winner (appearance mods) 2019
St. Jude Donor '08-'09-'12 thru'22
Nice work
Old Mar 29, 2008 | 02:26 AM
IDM's Avatar
IDM
no need, don't drive around town in reverse lol
can't hurt though
Old Mar 29, 2008 | 03:19 AM
jdmvette's Avatar
jdmvette
Night Owl for life
can't hurt though
yeah, true.
reverse lights are really just to let other drivers know you're backing up, not really meant for you to notice anything while sitting in the driver's seat.
still, a cool mod though.
