Starting Problem
Old Mar 28, 2008 | 08:28 PM
pikerunner's Avatar
pikerunner
Default Starting Problem
I am getting an occasional starting problem, all lights, power, etc but the starter does not engage. Battery and connections thereon check out.
Any thoughts?
Old Mar 28, 2008 | 08:41 PM
jacks996's Avatar
jacks996
Jacks996
Cruise-In VIII Veteran
pull the terminals off the battery and clean them. Check and see if your grounds are clean and tight.
Old Mar 29, 2008 | 02:47 AM
PierEagle's Avatar
PierEagle
After you do the above, turn your headlights on and try to start. Do the headlights dim a lot or go out and/or you hear a clicking? If so, take the battery to AutoZone or Advance and they will do a free "load test". If the lights stay bright, check the connections at the starter. Do you have an Auto or M6?
Post results.
Old Mar 29, 2008 | 02:51 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Does your security light go out? If not, you might try cleaning the pellet
Old Mar 29, 2008 | 02:56 PM
pikerunner's Avatar
pikerunner
Not to sound dumb, but was is the pellet?
Old Mar 29, 2008 | 04:17 PM
pikerunner's Avatar
pikerunner
I pulled the battery, cleaned all terminals and reinstalled. I only get a slight dim on starting with the lights on. It's a M6. I check the starter connection next.
Thanks.
Old Mar 29, 2008 | 11:50 PM
az57chevy's Avatar
az57chevy
The pellet is in the key and is near the head. It's the small "chip" sticking out
Old Mar 30, 2008 | 01:06 PM
stormrider's Avatar
stormrider
If none of the above works, 9 times out of 10 it is your starter starting to go bad. You can replace it yourself in about 1-2 hours plus about $100 for a rebuilt starter with a lifetime warranty or take it to the stealership and they will charge about $600 (at least that was the quote I was given).
To Starting Problem
