Tire size
Old Mar 29, 2008 | 09:33 AM
foundvettelifeisgood's Avatar
Default Tire size
Thinking of jumping from 17 / 18 to 18 / 19. Will the existing 18's fit the front, and what size tire goes on a 19 x 11 wheel for the rear?
Old Mar 29, 2008 | 12:40 PM
wamara's Avatar
wamara
Cruise-In II Veteran
Assuming you have stock coupe sizes now, a 275/40 -18 has too big of a sidewall height to use on the front. Again assuming you went with a 9.5" or 10" width 18" diameter wheel, you would want a 35 profile tire (e.g., 275/35-18). For a 19x11" rear, probably a 305/30-19 tire would work (or a 305/35 - not sure what sizes are readily available in 19s). As part of doing your homework, you need to check the tire mfrs' specs to see what range of wheel widths will work for any given tire size.
Old Mar 29, 2008 | 01:01 PM
Bill Vett's Avatar
Bill Vett
I'm running 265/35/18 front and 305/30/19 in the rear, this is the same rollout as the stock Zo6 sizes. You will have no abs or tc issues.
Old Mar 29, 2008 | 03:03 PM
I love this forum. Thanks for your help.
A tire calculator has the 245/40/18 nearly dead equal to 245/45/17. I might just go with 18's all around. My gripe is that the front 17 inch wheels look too small and the tire sidewall looks too tall. I like the 18s in the rear.
Any thoughts on not staggering to 19 in the rear with 18s in the front?
Old Mar 29, 2008 | 03:06 PM
chuck1026's Avatar
chuck1026
I am running 18x9.5", 19x11" with 245/40/18, 285/35/19.
No speedometer recalib. needed.
Old Mar 29, 2008 | 03:12 PM
AlisonC5's Avatar
AlisonC5
.... OR you could lower it. My $0.02
Andy
To Tire size
