Dumb Question 497 How to remove Console?
Old Mar 30, 2008 | 12:21 PM
Ta-taaa's Avatar
Ta-taaa
Default Dumb Question 497 How to remove Console?
Ok dumb question, I have been looking on how the center console come out, but have not found anything. What's the best way?
Thanks!
Old Mar 30, 2008 | 12:24 PM
chris308's Avatar
chris308
https://www.corvetteforum.com/techti...D=87&TopicID=1
Old Mar 30, 2008 | 12:26 PM
Ta-taaa's Avatar
Ta-taaa
perfect! thanks!
Old Mar 30, 2008 | 12:31 PM
chris308's Avatar
chris308
your welcome!
Old Mar 30, 2008 | 12:34 PM
RJ1AZ's Avatar
RJ1AZ
From: PHOENIX, AZ Yes, it's true. You are a good woman. Then again, you may be the Antichrist.
Just going off memory here, but there are two nuts at the rear, under the console cushion, hidden beneath little plastic covers that you pry out. There are two more at the front, hidden beneath that half moon panel that has the traction control switch. You can pry that panel out with a small screw driver. It comes out pretty easy. Disconnect the wiring to the gas door switch, and that should be it. Shouldn't take more than 5 minutes.
To Dumb Question 497 How to remove Console?
By Michael S. Palmer | 2026-06-03 11:00:24
