Stuck Lug Nuts
Old Mar 30, 2008 | 01:01 PM
jealkon's Avatar
jealkon
Default Stuck Lug Nuts
Never had this problem and am scared to death I am going to break something.
Wheels have never been off the car (2002) except for inspections - went to take them off the clean and I can't break the lug nuts free. I tried using a breaker bar for leverage, and even tried hitting the socket wrench with a mallet - No luck
Anyone have any ideas on how I can break these free?
Old Mar 30, 2008 | 01:05 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
try a cross lug wrench. better leverage and power.
Old Mar 30, 2008 | 01:09 PM
Kamil D.'s Avatar
Kamil D.
1000%
Old Mar 30, 2008 | 01:19 PM
hotwheels57's Avatar
hotwheels57
If they've never been off, there may be some rust involved. You might try an impact wrench. If you find rust on the lug nuts, there's probably evidence of rust on the rotor to hub as well.
Replace the lug nuts with better quality show chrome or black GORILLA lug nuts/locking lugs. They're available from site supporting vendor HOUSE OF WHEELS or your local DISCOUNT TIRE (@ 100# torque).
Old Mar 30, 2008 | 01:21 PM
10U 99's Avatar
10U 99
sounds like someone got over zealous tightening them. 100 ft lbs should be no problem for a 16" 1/2" drive bar. find a piece of pipe to slip over the bar to use as a cheater. there's alway an impact but they are hell on chrome nuts.
Old Mar 30, 2008 | 04:15 PM
4440stevesvette's Avatar
4440stevesvette
I had the same problem last Fall when i pulled the wheels off my just bought 99 FRC. I had to slip the pipe handle from my floor jack over my 1/2 inch breaker bar to break them loose. now they are torqued to 100 ft. pds. courtesy of my new sears torque wrench.
Old Mar 30, 2008 | 11:28 PM
az57chevy's Avatar
az57chevy
As strange as it may sound try tightening them just a bit and then loosen. it'll work
To Stuck Lug Nuts
