Please Help... A\C Question
Old Mar 30, 2008 | 06:29 PM
VetteFanatic007's Avatar
VetteFanatic007
Default Please Help... A\C Question
Gang… I went on a trip where I was gone for three days, when I returned my Vette would not start. The battery is a Die Hard Gold. The car is a 99’ A4 Coupe with 87K. I used the instant start feature on my battery charger, and off I went to Sears. Sears said that the battery is still under full warranty and it would be ready in 1.5hrs. I went back to pick my car up and the advisor told me that there is nothing wrong with the battery, not my alternator, not starter. He said that the battery just needed to be charges, so that is what they did.
After pulling out of the parking lot, I flip on the A\C to combat the Florida heat. The passenger side was blowing extremely hard and very cold, while my center vent and driver door vent was very faint and very warm. I set the thermostat to 60 and cranked the fan to high. After a 10 minute ride back to the house, nothing had changed.
I called the guy at Sears and asked if they unplugged a hose or something, and he said no. He said it was some sort of “node” motor that controlled the pressure of flow between the driver and passenger side. He said that since the battery had such a low voltage, the node freaked out or something. He told me to take the car on a 20 minute ride and it would reset itself. I went on a 25 minute ride and nothing.
If this “node” is the problem, how do I reset it? Or what else could it be? It was working fine before I left for my trip, but it isn’t working now. Please help…
Thank You,
VF007
UPDATE- I tried removing fuses 18 & 27 (twice) and the problem still exists. I tried reindexing via the on-board DTC, still have the problem. I will try adjusting the actuator by 2 teeth counter clockwise this weekend. All of this because my battery died. I hope this works, If not I will have to bite the bullet and take it to Chevy. I'll keep you posted.
4/26/08 The DIC codes are gone, and the A\C worked briefly. Now it is doing the same thing again, but still not DIC codes. I am going run to autozone and have them check the freon. If it is not low, then I will remove the battery and check for a break in the hose.
5/10/8 Cold A\C again. I took it to "The Corvette Shop of Tampa". It was not the actutater. It ended up being the A\C control unit. I was told that during the tests, it would blow cold, then hot, and stay at hot. They replaced the unit and she blows cold. Thank you all for the input.
Old Mar 30, 2008 | 06:37 PM
Cozmo's Avatar
Cozmo
CentralTX Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
I have never heard of this "node issue". Have you checked your AC fuses?
Old Mar 30, 2008 | 06:39 PM
2kbluevette's Avatar
2kbluevette
Hello neighbor
As far as I know the venting selection is done by vaccum and has nothing to do with any "node".
The vaccum hose that control the vents runs under the battery. Sometimes, because of a battery leak, the plastic hose gets broken and all vents start to work. (I know it is happening to my 2000 A4 now).
I believe you have 2 distintive problems.
1-Slow drain in your electrical system
2-Some malfunction in the vaccum line
Hope to shed some light into your problem
Old Mar 30, 2008 | 07:02 PM
VetteFanatic007
I have not checked my A\C fuses, but I will do that now. Air is coming out the main vent, but is warm and faint. The passenger side blows high and cold.
Old Mar 30, 2008 | 07:04 PM
VetteFanatic007
Originally Posted by 2kbluevette
Hello neighbor
Sears said that the battery was 100% operational, but I will try removing the battery an visually inspecting it myself. On a side note, my next door neighbor has a 2004 A4 and had the same battery leak problem that you did.
Old Mar 30, 2008 | 08:21 PM
2kbluevette
Do you have cimate control or regular A/C?
Old Mar 30, 2008 | 11:12 PM
VetteFanatic007
Climate control (dual A\C)
Old Mar 30, 2008 | 11:19 PM
2003 electronblue's Avatar
2003 electronblue
Default i just had that problem fixed
its the actutater, it needs to be recalabrated or replaced. your vent door is not opening up properly. it cost $214.00 plus labor.
To Please Help... A\C Question
