1/4 101
Old Mar 31, 2008 | 01:40 PM
ynotsquare's Avatar
ynotsquare
Default 1/4 101
I bought my Vette a few months ago and I wanted a few pointers before I go on the track (mainly at take-off).
2002
A4
3.15
Blackwing
Borla Stinger
Predator Tune
Old Apr 1, 2008 | 12:47 AM
itzza427's Avatar
itzza427
I drive a stick myself,but most techniques apply. 1.turn off traction control(hold button down for message traction control off,keep holding down and you get competition driving,let' wheels spin helps keep you straight) 2. Back into water/do short burn out 3.stage 4.Torque motor (guessing about 11/1200 rpm) 5. leave on 3rd yellow-- When you leave don't just slam it to the floor do a "quick controlled feed to the floor" (ranger) flooring it will just result in frying the tires and wasting e/t.,,from there just run it out through the traps. You might want to find a deserted place to try a few torque it up starts to get a feel for a quick start with out going up in smoke. With this basis you should get a good reaction time,and with a good pass get into mid to low 13s @ 105/110. this should get you started off on the right foot---Have fun Any questions shoot me a PM
Old Apr 1, 2008 | 08:52 AM
JEEP/C5's Avatar
JEEP/C5
With an A4 you want to shift into 3rd (no OD) and leave it. Follow above info and you will do fine. The A4 will give you much more consistent results compared to a M6. Practice as much as you can.
Old Apr 5, 2008 | 11:19 PM
ynotsquare's Avatar
ynotsquare
Thanks for the info.
Old Apr 6, 2008 | 05:12 PM
itzza427's Avatar
itzza427
Let us know how it goes!! For you and the car,,I always say "about as much fun as you can have with your cloths on"!!
Old Apr 6, 2008 | 08:41 PM
Vega$Vette's Avatar
Vega$Vette
Step on the right pedal and hold onto the round thing that makes it go straight.
Old Apr 6, 2008 | 11:02 PM
slow98cobra's Avatar
slow98cobra
If you are on street tires DO NOT go into the water box or even back into it. The grooves on your tires can track water up to the starting line and cause issues for other drivers. Drive around the water box and do a quick scuff burn out to clean off the dirt on your tires. Street tires do not need to be roasted like slicks. If you burn them out too long then they will actually become "greasy" and hurt your 60'.
Old Apr 25, 2008 | 09:54 PM
ynotsquare's Avatar
ynotsquare
Hey guys. On the first run, I ran an 13.4. I wanted to do one more and I ran an 13.1. I think I can get a few more tenths off if I get a good start. That xmas tree is a little tricky when doing it for the first time.
Old Apr 25, 2008 | 10:16 PM
J S Machine's Avatar
J S Machine
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17
St. Jude Knife Maker
I think alot of it is in your reaction time. It takes alot of practice to cut a good light. It's kind of a gamble there. If you wait for the green you might as well pack up and go home. If you take the gamble and time it just right to leave off the back side of the 3rd yellow, You'll start seeing better times. You will red light every now and then, but if you are doing test and tune you aint losing anything. There is a fine line between red lighting and getting it right. You think that tree is hard, try running a pro tree...
Old Apr 25, 2008 | 10:58 PM
jacks996's Avatar
jacks996
Jacks996
Cruise-In VIII Veteran
If you put in a 3.42 rear I bet you can take off .500
Old Apr 26, 2008 | 12:23 AM
itzza427's Avatar
itzza427
About as good as you can do on street tires,,,Drag radials will let you leave harder. I see an extra set of wheels in your future.Shorter tires(smaller circumference) will give you the same effect as lower gears,that you can take off when you leave the track.
Old Apr 26, 2008 | 02:08 AM
vettegator005's Avatar
vettegator005
good advice.
Old Apr 26, 2008 | 08:30 AM
Mister Peebody's Avatar
Mister Peebody
From: Ok! So you don't believe in conspiracies, but will you acknowledge the possibility of there being coordinated activities in secret places? Texas
Reaction time has nothing to do with E.T.
For the most part, E.T. is a measure of the car - R.T. is a measure of the driver
If the best his car is capable of is a 13.1, he can cut a perfect light and still only run a 13.1.
On the other hand, if he's racing a car that is also only capable of 13.1
and the other driver is asleep at the tree, a better reaction time can win the race for him.
You can run a faster E.T. and still lose the race. HTH
Old Apr 26, 2008 | 09:17 AM
park83's Avatar
park83
R/T only matters in a competition. You could sit there for 10 seconds before launching and still run a quick time, it just wouldnt help much in an actual race. If you're going for a good ET, just focus on the launch, not the timing.
Old Apr 26, 2008 | 09:20 AM
itzza427's Avatar
itzza427
A rule of thumb,,every 1/10thsecond is about a car length..I' had as much as 3 to 4 tenths,really out there in front.
Old Apr 26, 2008 | 01:05 PM
motogib1's Avatar
motogib1
If you are trying to get the best ET out of the car, who cares about reaction time? Take your time and set up your launch. Power break up to the rpm your breaks can hold and and release. Squeeze the pedal, do not mash. My best 60' time and ETs keep getting better with less throttle off the line.
To 1/4 101
